fuel pump ground wire
Old Apr 24, 2015 | 11:16 AM
lowflyer's Avatar
lowflyer
Default fuel pump ground wire
In changing my fuel filter (`09 RG) I noticed a ground wire that doesn`t seem to connect to anything. It is next to the fuel filler neck. Any clue to it`s purpose? I would think it might have to do with static charge but don`t understand how it works without direct contact to anything. It is a single black wire opposite the fuel pump plug and they are removed when changing the filter. I am regarding the filler neck as a non-conductor being it`s plastic.
Old Apr 24, 2015 | 01:11 PM
J929626's Avatar
J929626
I think that it is supposed to be held in place by the retainer clip. It bridges the gap between the filter shell and the top plate that would otherwise be isolated by the o-ring.
Old Apr 25, 2015 | 08:46 AM
lowflyer's Avatar
lowflyer
Guess my wording led to misinterpretation. The wire branches off the main plug at the fuel pump. Then it anchors into a spot next to the filler neck. When removing the fuel pump assembly to change the F/F the plug and ground wire are removed from their respective spots to facilitate replacement of F/F. The black wire doesnt touch anything but the plastic. Must have to do with preventing a static spark when filling tank with fuel?
wborden
May 6, 2014 01:59 AM
rdondes
May 18, 2013 02:52 PM
Bartman1959
Jun 22, 2012 07:12 PM
rgardjr
Jun 22, 2012 12:47 PM
99superglide
Apr 9, 2010 08:05 PM
