Transport mode
Old Jun 20, 2017 | 08:49 PM
Spilot's Avatar
Spilot
Default Transport mode
Following instructions in the owners manual to the letter for setting security system to 'transport mode' but it's not working. Anyone else have this problem and found a solution?
Old Jun 20, 2017 | 09:07 PM
Mikes145's Avatar
Mikes145
Do you have the key fob nearby?
Old Jun 21, 2017 | 08:42 AM
Spilot's Avatar
Spilot
Yes. I may have figured it out. The owners manual says the turn signals will blink "once" to indicate it is in transport mode. Mine blink three times, but after setting it I took the fob to another location and them moved the alarm did not activate.
This is a new bike, and will be transporting it soon. Don't want to,arrive at destination with a dead battery!
Old Jun 21, 2017 | 09:49 AM
Zanthamos's Avatar
Zanthamos
I know transporting bikes via Household Goods shipment for military members requires the battery to be disconnected during transport.
Old Jun 24, 2017 | 10:37 AM
grbrown's Avatar
grbrown
Red face
If it has an alarm it'll howl it's head off if the transport mode doesn't work! If in doubt disconnect the battery.
Old Jun 24, 2017 | 05:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Turn ignition switch on then off, press both signal buttons and the signal lamps will light once (as you press the signal buttons), but... a few seconds later the signal lamps will blink three times (the manual doesn`t tell you that), it caused me some confusion too.
Graham: If you disconnect the battery, the alarm siren will sound off, it has its own battery...
Old Jul 2, 2017 | 09:12 PM
Knutson Boltz's Avatar
Knutson Boltz
Dan is right. I've transported mine via trailer twice and the manual had explicit instructions and it worked perfectly.
Rick S
Mar 14, 2019 03:43 PM
bell927
Aug 23, 2012 12:26 PM
bswearingen
Jun 12, 2011 08:18 PM
Rick14221
Jun 4, 2011 10:30 AM
hogsolo
Aug 10, 2009 06:48 PM
