LED lights flashing eratically
I added two strips of LED lights that have a flashing module under the tank, two plain strips under the bags and two pods on the metal partition under the seat. When the engine is not running the pods and bags burn steady and the flashers follow whatever pattern I select.
When I start the engine, the pods and bags stay constant as they should but now the flashers just flash eratically (sp?). If I hold down the "mode select" button, it will stop and whatever LED's were lit when I pressed the button stay solid. There is no remote, the "mode" button is hard wired.
Could this be over-amp from the coil pack since the wiring is all stuffed in the cavity below/in front of the battery above the coil pack?
Worst case, if I have to take them off, is there a good way to release the 3M adhesive? I used the surface prep so they are stuck on really tight.
I ran a fused wire from the battery to a switch to a wiring block. All the positive sides go to the block. The negatives wired to a block off the negative side. So activating the switch, closes the circuit for all the lights to come on. The lights that are made to be solid work fine, only the ones using the flash mode get affected with the motor running.
With the engine off - they operate as they should.
Pretty stumped. I even tucked all the wires into a rubberized sunglasses bag to see if that would help shield them from any signal down below, but that didnt help at all.
I'm just stumped.
I guess I'll pull them off and just replace them with plain color strips that dont change and be happy I have more lights to be seen if not "bedazzle"...:/
Also some heat with a blow dryer on LOW SETTING from several inches away will help to loosen and soften it before using chemicals.
If shielding is the issue, try wrapping in foil instead of rubber. Lastly, maybe the vendor can suggest or help trouble shoot the issue. I LOVE Custom Dynamics because of their customer service, and they also answer the phone when you call, just in case you decide to try a different brand of electronics
Good Luck gremlin chasing, it is frustrating
Last edited by sparkalot; Jul 27, 2017 at 11:22 AM. Reason: spelling IC, added words
On another note, I installed the filler lights from custom dynamics as well. Good LORD they are BRIGHT even in the Texas sun!
