A little wiring help please
Old Jul 29, 2017 | 11:00 AM
user 9370's Avatar
user 9370
Default A little wiring help please
I'm attempting to add a siren to the security system on my '15 Dyna. I know I could spend the $$$$ and just buy the HD unit but I found this (https://www.hdforums.com/forum/touri...-2011-rgc.html) topic and thought I'd give it a try.
The instructions state to connect the red wire from the siren to the brown wire from the plug and the black siren wire to the green plug wire. My problem is, the plug I have has a red wire, a white with grn stripe and a black. The electrical schematic shows the white/grn stripe to the OEM siren and the black is ground. I tried that (red to white/grn and black to black.) That didn't work although the siren made a faint "buzz" when the battery was reconnected. I didn't try anything beyond that (afraid to fry the harness) and could use some expert advise.
Thanks,
Ray
Old Aug 2, 2017 | 12:15 PM
Zanthamos's Avatar
Zanthamos
Black is not necessarily ground, in this case ground is most likely reached via the security module that the siren is attached to as it can still be able to sound if the power was cut. I would go red to red then black to wht/grn.
Old Jan 6, 2019 | 04:39 PM
HuntWhenever's Avatar
HuntWhenever
Thanks,
Ray
Ray,
did you ever get a solution to this? I am trying to wire up a siren to my 2019 Sport Glide. Electrical schematic seems identical to your Dyna...GRN/WHT for Siren Signal, BLK for Ground, RED for Battery Power. Also, my installation went the same as yours...momentary faint buzz when I plugged my main fuse back in.
Old Jan 14, 2019 | 08:31 PM
HuntWhenever
If anyone else stumbles upon this same situation, the wiring for the security siren connector using the RED/ORG, GRN/WHT, and BLK wires is as follows...
Basically...Siren (+) to RED/ORG, then Siren (-) to GRN/WHT.
Old Jan 15, 2019 | 11:46 AM
Zanthamos's Avatar
Zanthamos
Funny, I said exactly that in post #2.
Old Jan 15, 2019 | 07:58 PM
HuntWhenever
I just wanted to put some verified results down on the board.
Old Oct 30, 2019 | 02:21 PM
CAJ411's Avatar
CAJ411
That was a great post for older bikes, bu
Old Dec 11, 2019 | 01:11 PM
jimsreddyna's Avatar
jimsreddyna
I have been reading and searching my 2019 Sport Glide for the alarm siren connector plug and I am dumbfounded!
Does anyone have pictures, a road map or a tip as to it's location on the Sport Glide?
Old Dec 11, 2019 | 01:36 PM
HuntWhenever
I don't have any pictures, but it is a pain to get to. You have to remove your battery to get to it. Between your battery tray and the rear wheel is the BCM (Body Control Module). Its nested under that black plastic rear fender mud-flap kinda thing. The pigtail for the alarm siren is connected to the BCM.
Old Dec 12, 2019 | 10:52 AM
jimsreddyna
I saw a u tube video were the guy recommended taking the rear fender off to get access to it.
