High Voltage - should I ride it home?
Old Sep 27, 2017 | 10:57 AM
bladeguy's Avatar
bladeguy
Default High Voltage - should I ride it home?
My voltage is starting to push 15.5 volts on a 2012 FLHTK. I searched and found that I should replace that voltage regulator as it can fry the battery. I rode 30 miles in to work this way. I have a Harley dealer near work. The question is can I buy the regulator and ride it home to fix or should I pay the dealer to change it to insure that I don't damage any other components. Thanks in advance.
Old Sep 27, 2017 | 12:13 PM
strych9's Avatar
strych9
Fix ASAP. The battery will get damaged and overheat if it's overcharging. Heat is a mortal enemy to a battery.
Old Sep 27, 2017 | 12:55 PM
bladeguy's Avatar
bladeguy
Do you think it is damaged already? I believe it just started today - 30 miles...
Old Sep 27, 2017 | 01:02 PM
soft 02's Avatar
soft 02
When my reg went out on the way home it was running at 18 volts. Replaced the reg and it was back to normal. Didnt hurt the battery but you are rolling the dice.
Old Sep 27, 2017 | 01:49 PM
GRWHD's Avatar
GRWHD
I had this happen to a Suburban years ago (I know not a bike).
We were 55-60 miles from a town.
So we drove it to the nearest gas station/shop.
When we got there the battery was about to pop.
It was a brand new sealed battery (back in the day most were not).
We got lucky it did not explode.
I would fix it ASAP, test the battery and replace if needed.
Old Sep 27, 2017 | 04:18 PM
bladeguy's Avatar
bladeguy
I ordered a regulator for $120 less than at my local dealer. Going to try and make it home. If I buy a new battery I am just about even. If the stator goes that is a whole other story...
Old Sep 29, 2017 | 10:24 AM
bustert's Avatar
bustert
it can be normal for an over 15 to occur on occasion and the battery will not bulk until it passes the 16 level. the protection circuit zener is around 14.7>15.2. i would have the battery and associated wiring checked first since any resistance here can fool the regulator, even an iffy battery that is sulfating.
Old Sep 29, 2017 | 11:22 AM
bladeguy's Avatar
bladeguy
It is pretty much pegged at 15.5 when not at idol. I will check the battery and wiring. Could this be indicative of a voltage regulator going bad? If I don't find anything wrong with the wiring I will install the new regulator. If the voltage goes down then I know. If not I will keep looking.
Old Sep 29, 2017 | 11:58 PM
bladeguy's Avatar
bladeguy
So I get my new regulatorand installed it - and it seemed worse! Went to 16V and that is as far as the meter goes. Instructions say check your grounds and test voltage at the battery. So I did both. Son of a bitch the voltage at the battery was right around 14.5 when the meter on the bike said 16. Guessing bad volt meter. Dang!!! Learned a lesson. Think I will leave new (aftermarket) regulator on and carry the old for a spare. At least I can ride!
Hogpro
May 9, 2023 04:16 PM
T Man
Jun 12, 2017 02:13 PM
jmg343
Jul 9, 2012 07:04 AM
Failz
Mar 17, 2011 12:38 PM
NSCoyote
Oct 10, 2009 04:04 PM
