Voltage regulator
Old Apr 16, 2019 | 08:00 AM
Robert Wayne Nichols's Avatar
Stage III
Default Voltage regulator
Ok guys I'm getting 14+ vdc at the regulator but its not getting to the battery. Any help will be greatly appreciated. Thanks
Old Apr 16, 2019 | 09:39 AM
bustert's Avatar
bustert
i assume you are dc out to ground at the regulator?
make sure the regulator case has a good ground. then check all ground points. check for bad connections and then battery cables. a good schematic does help.
Old Apr 16, 2019 | 02:45 PM
Stage III
Thanks Bustert.... I have the schematic will check ground its a new aftermarket reg.
Old Apr 16, 2019 | 03:11 PM
Vernal's Avatar
Vernal
Hi Robert and welcome to the Forum from Utah.
It's always a good idea to post what year and model bike your working on.
Like bustert I'm curious how you checked the output of the VR.
Here is a write up on how to check the charging system on a touring bike.
Testing:
Connectors and cables should be checked and cleaned first. Loose and corroded connectors, terminals and grounds can cause high resistance, impeding current flow. Check cables for broken or rubbed insulation and check continuity to make sure the conductor is not broken inside the insulation.
Coating connectors with dielectric grease will keep moisture out and reduce corrosion.
Use the schematics in the HD Electrical Diagnostic or Service manual to determine the location of additional connectors.
Battery testing:
First check and clean battery terminals, Battery cables and ground connections. To check cables, disconnect one end and Ohm out, wiggle while testing. Cables can and will corrode and the evidence can be concealed under the insulation.
If you are unsure of the battery’s condition charge it fully and take it to an auto parts store and have it load tested.
Voltmeter test:
Connect voltmeter positive to positive terminal on battery and voltmeter negative to battery negative terminal.
12.7 v = 100% charge
12.6 v = 75%
12.3 v = 50%
12.0 v = 25%
11.8 v = 0%
Watch the battery voltage when you start the bike, if a fully charged battery falls below 9.6 volts it’s time to replace it.
If a well charged battery runs down if the bike sits for a short time perform a current draw test. Set your meter to read 10 amps current. Pull your main fuse and insert the meter leads. Here’s a list of components and what current they will draw in milli amps, 1/1000 of an amp) from the 2015 manual:
LHCM 0.5
RHCM 0.5
Speedometer/ IM 0.5
Regulator 1.0
ABS 1.0
BCM 1.0
ECM 1.0
Security Siren 20.0
Radio 0.5
Amplifier 0.5
CB Module 0.5
If the Battery passes all tests check the charging system.
Charging System Testing:
Volt meter set to DCV 20V scale or higher.
With the bike in neutral and voltmeter attached to the battery, start the engine and rev to 3,000 rpm. If the voltage measures 13V – 14.7V the charging system is operating properly. If less than 13V test the Stator first. If Greater than 15.5V test the Voltage Regulator.
Stator testing
Turn the bike off and disconnect the Stator from the Voltage Regulator.
Testing a 3 phase Stator, (A single phase stator is tested in the same manner but the plug will only have 2 sockets).
The end of the connector from the stator has 3 sockets. Set your meter to ohms and connect one lead to the battery negative. With the other lead make contact with the conductors inside each socket. You are checking for a grounded coil winding, each socket should show an open circuit to ground, no continuity.
Now take both meter leads and check resistance between each of the three sockets, 1-2, 2-3 and 1-3. The resistance should be 0.1 – 0.3 ohm.
Next check the Stator’s AC output. Set the meter to ACV 100V scale. With the Stator unplugged from the VR and the bike in neutral, start the bike. Run the bike at 2,000 rpm and check the Stator output between sockets 1-2, 2-3 and 1-3. The voltage should read approximately 32-46 Volts AC, for the 50 amp Stator. Stators with other Amp ratings will be similar.
If the Stator continuity tests to ground and Phase to Phase are good but the output is not the Rotor may be bad.
One other indication that the stator may be bad is if your primary oil smells like a burnt circuit board.
Voltage Regulator Testing
Voltage readings of 15.5V and higher test wire from VR negative to battery negative, if less than 0.5 ohm replace Voltage Regulator.
If the output is less than 13V from the Voltage Regulator to the battery and the Stator output is good, disconnect the output cable from the VR to the Battery. Check continuity between the Voltage Regulator Positive wire and the battery Positive and the negative wire and battery negative. Repair or replace cable if needed. If the cables are good and the Stator tested well replace the Voltage Regulator.
Old Apr 16, 2019 | 03:14 PM
Vernal's Avatar
Vernal
Here are a couple schematics from 2014 touring manual:
Old Apr 16, 2019 | 07:46 PM
Stage III
Thanks Vernal.
Its a 2007 ultra the stator tested good..
New regulator installed . I tested it at the positive output to the battery getting 14.3 , if i plug in the battery connection and test at battery 11.6 im no expert but the problem has to be between the regulator and the battery please correct me if im wrong....
Old Apr 16, 2019 | 08:48 PM
Vernal's Avatar
Vernal
With the bike off what voltage do you have at the battery? If it’s not 12.8 or higher take the battery out and put it on a charger. When it’s fully charged get it load tested. Check resistance from VR cable + - to ground and + to battery positive cable.
2009blackpearle
Electrical/Lighting/Alarm
26
Nov 22, 2024 05:16 AM
Fscott4
Sep 1, 2018 11:30 AM
Sauraus
Mar 14, 2017 09:45 AM
Bxmarauder
Nov 8, 2016 07:11 AM
Kopazzz
Sep 21, 2016 08:28 PM
