Female 2 wire plug behind headlight?
Old Jul 23, 2019 | 08:50 AM
taf0104's Avatar
taf0104
Originally Posted by MURPHCC1
Do you have passing lamps?
Yes... stock passing lamps. Looking at the wiring diagrams... it looks like the blue and black wires are for passing lamps. This seems to be an accessory plug for something else .
Old Jul 23, 2019 | 10:30 AM
Vernal's Avatar
Vernal
What color are the wires?
Look at the upper left of drawing .
Old Jul 23, 2019 | 10:58 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Cut it off and put in your own male and female plug.
No, don`t hack up the wiring harness...
The bike has a P&A connector under the left side cover, it can supply switched or unswitched power, whichever you want depending on which wires you connect to.
You make up a Molex MX-150 (gray) connector with the wires at the appropriate location in the connector, run the wires up to where ever you want. The power can be controlled by the ignition switch or by the switch on the back of the fork tin.
Old Jul 23, 2019 | 11:28 AM
taf0104's Avatar
taf0104
Ok.... it looks like it is the front fender tip lamp connector. Diagram has it as connector 32A. If I could source the Male half of this plug I could make up a short lead(12") rather than running all the way from the left side panel accessory location.
Old Jul 23, 2019 | 12:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Looks like it is the position lamp connector, 29 B.
Look at the wiring diagram, it shows a position lamp connector for FLHR, Blue and Black wires.
You may not find a mating connector, it is designed to go onto a component that has spade connectors (a lamp).
Old Jul 23, 2019 | 03:13 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Look about 6'' back from your headlight plug for a orange wire with a white stripe and a black wire ( they should have a blade connector on them ). Orange will be positive and black will be negative, they are a switched power supply.....
Old Jul 24, 2019 | 03:29 PM
taf0104's Avatar
taf0104
You are correct! Went to dealer to look at their parts fische.
Position lamp plug on for International HDs
CanadianHD
Mar 22, 2018 08:45 PM
mclowrider
Feb 16, 2018 10:33 AM
MikeBel
Jun 11, 2013 03:11 PM
Rubbit
Feb 14, 2009 08:05 AM
klf33
May 30, 2008 10:46 AM
