Cruise control not working
Old Nov 1, 2019 | 07:31 AM
RINI88's Avatar
RINI88
4th Gear
Post Cruise control not working
Good morning everyone, I have a 2016 Harley Davidson Softail Fat Boy S FLSTFBS ,
I replaced all the lights with aftermarket bulbs from Custom Dynamics Motorcycle LED Lighting.
I started noticing that the green light on the speedometer wasn't always working when the bike was in six gear.
Shortly after that my cruise control was doing the same thing, along with the RPM that show you what gear
you are in stopped working as well, It only shows the rpm not what gear the bike is in.
Cant seem to find out why this is happening, those anyone have any suggestions ???????
Old Nov 1, 2019 | 08:44 AM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
If you're suspecting that all this started when you replaced the lights, put the old lights back in and see if you still have the same issue.
Old Nov 1, 2019 | 08:53 AM
RINI88's Avatar
RINI88
4th Gear
Default cruise control not working
Hey Brandon, thanks for the recommendation but i have tried that as well, im thinking i have to put the
old computer back in and see if a code pops up that might be able to pinpoint the problem.
Old Nov 1, 2019 | 09:02 AM
Uncle Larry's Avatar
Uncle Larry
Just a thought ... Try cleaning ant residue from the neutral indicator switch ... Part #22 in the attached link ... Good Luck
http://partsfinder.onlinemicrofiche....ING%20ASSEMBLY
Old Nov 1, 2019 | 09:10 AM
RINI88's Avatar
RINI88
4th Gear
Is that the speed censor as well ?? I will try that, thanks Uncle!!
Old Nov 1, 2019 | 09:15 AM
im's Avatar
im
Your description is missing pages.
What old computer ?
What green light?
In the most general terms the bike needs to know traveling speed in order to lock a speed in.
A tail light that is illuminated for BRAKE would probably knock out a cruise control.
From a distance it reads like bike might not be reading speed for some reason.
Generally speaking when a new item is introduced and creates a problem then such an item should be removed in order to isolate the situation.
Old Nov 1, 2019 | 09:43 AM
RINI88's Avatar
RINI88
4th Gear
I installed an ECM w/autoune 16-17st, but the bike was running normal had no issues,
I changed the tail light is when i noticed the green light on the speedometer was working on and off along with
the cruise control, Green light indicated your in six gear, little by little they stopped working all together.
Old Nov 1, 2019 | 11:44 AM
Texas Guy's Avatar
Texas Guy
I put Custom Dynamics inserts on my ‘18 Roadglide; shortly after my engine gauges cut out and I lost cruise control; turns out the voltage regulator was to blame.
After replacement of the Voltage regulator under warranty, I took a chance on the LED inserts again; this time no voltage problems.
Old Nov 3, 2019 | 10:32 AM
RINI88's Avatar
RINI88
4th Gear
Hey thanks for the heads up will definitely check that out ....................
FtpdMoose
Sep 3, 2012 11:39 AM
TexasVet
Aug 12, 2011 08:53 AM
les63
Oct 7, 2010 02:39 PM
Ridewva
Jun 16, 2009 09:21 AM
ebaswell
Apr 28, 2005 03:56 PM
