Need Help. No Spark 05 Fatboy
Old Jan 7, 2020 | 02:12 PM
Bspike1's Avatar
Bspike1
Default Need Help. No Spark 05 Fatboy
05 Fatboy fuel injected has no spark. Cranks but doesn't fire. Have replaced the CKP sensor and the coil. Any Ideas where to look next or further troubleshooting ideas?
Old Jan 7, 2020 | 02:14 PM
Scudda's Avatar
Scudda
What is your battery voltage? I had an issue with mine that was close to the same. It turned out to be a bad battery
Old Jan 7, 2020 | 05:25 PM
Bspike1's Avatar
Bspike1
new battery as well. It's not showing any codes
Old Jan 7, 2020 | 10:27 PM
Crotonrz's Avatar
Crotonrz
It’s almost never the coil, the CKP is more common, but I’d check your ECM connector for corrosion possibly.
Old Jan 7, 2020 | 11:06 PM
chief08's Avatar
chief08
check the system relay
Old Jan 8, 2020 | 03:48 PM
Vernal's Avatar
Vernal
The system relay also powers the Fuel pump, OP never mentioned if it comes on and runs for 2 seconds.
Old Jan 8, 2020 | 03:56 PM
Jackie Paper's Avatar
Jackie Paper
How are you checking for fire. You need plugs in. A test plug grounded to cylinder. Also needs perfable a Harley Plug. Your old system uses resistance read by coil to adjust timing for spark knock . Although NGK has a lookalike plug and will work, it's twice the resistance of a Harley plug. I have run them but drive easy. Not sure how accurate system will be to aggressive ridding
Old Jan 9, 2020 | 06:07 PM
Bspike1's Avatar
Bspike1
Fuel pump comes on when you turn the key switch. Checked plugs out of cylinder and grounded the the engine
Old Jan 9, 2020 | 07:30 PM
Vernal's Avatar
Vernal
Harbor freight sell a plug tester like the one pictured.
Old Jan 10, 2020 | 09:41 AM
Zanthamos's Avatar
Zanthamos
Does the bike have a power commander installed? If so disconnect it and check the connections for the ECM, I have seen quite frequently that the plugs on the power commander get full of water causing all kinds of issues including no spark. Try plugging the main harness back into the ECM. Is there security system on the bike? Look for flashing turn signal lamps, HD factory security system will disable the ignition circuit and the start circuit, I have seen a fail of the TSSM cause the start circuit to function but the ignition to be disabled.
troygalloway
Sep 18, 2016 09:57 PM
Mugsy666
Aug 3, 2016 08:19 PM
NomoreNomad
May 25, 2016 03:11 PM
BRUMM
Jun 26, 2013 04:37 PM
Tribe of Judah MM
Jun 20, 2012 10:25 AM
