battery optimiser
Old Aug 17, 2020 | 01:42 PM
camomanofcranham's Avatar
camomanofcranham
Default battery optimiser
Hi guys, I'm looking at getting a battery optimiser type as my fat boy tends to have trouble starting if I dont use it for a week or so which is due to the alarm I guess. I have a few questions: what make is best? do they actually work? what life expectancy would you get for the battery would you hook the charger up all the time?
I added a poll if this helps..
Thanks in advance guys...
Old Aug 17, 2020 | 01:46 PM
squirrelsnest's Avatar
squirrelsnest
https://www.batterytender.com/Battery-TenderR-Plus
Old Aug 17, 2020 | 01:48 PM
camomanofcranham
thanks for the quick response
Old Aug 17, 2020 | 02:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Battery tender is not a cure for a battery that won`t start the engine after a week. I suggest you check the battery and charging system.
I left my `16 Road King in storage for almost 3 months during a move, when I got it out of the storage unit it fired right up.
The alarm had not been disabled.
Old Aug 19, 2020 | 05:13 AM
camomanofcranham
I have checked the battery off the bike it holds a charge for over two weeks, checked the voltage insitu it was holdin 13.7 volts fired up the bike it shot up to 14.5. done this test with the "old" battery and a new one I got thinkin it was a battery issue, Im leaning towards the alarm drawing the power for the battery, it has also crossed my mind to put the bike into workshop mode which stops the bike lookin for the fob...
Old Aug 28, 2020 | 08:03 PM
Zanthamos's Avatar
Zanthamos
Do a power draw test and see what you get. The security system doesn't normally draw much power but the siren will if the siren battery is low, it charges the siren battery from the bike battery.
Old Aug 29, 2020 | 11:18 AM
larsfum's Avatar
larsfum
Think about it. You can leave your car sitting for months with the security system on, and it will still start. A bike sitting for a week should not drain the battery.
Old Aug 29, 2020 | 11:23 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Subtle difference though as my car has a 100Ah battery and my bike has a 12Ah battery but the security system in each probably draws about the same current.
Old Aug 29, 2020 | 12:55 PM
TriGeezer's Avatar
TriGeezer
Our batteries like to be at 100% as much as possible, Therefore, I always put my bike on my Battery Tender in the garage.
camomanofcranham
Electrical/Lighting/Alarm
Aug 17, 2020 01:45 PM
Bob Z.
Jun 24, 2017 09:49 PM
sbcvulcan
General Topics/Tech Tips
Apr 23, 2015 11:22 AM
gunnerchevy
Apr 28, 2013 07:43 AM
frenchman
Oct 8, 2011 05:49 PM
