Quick question on Tach wiring
Old Aug 19, 2020 | 08:38 AM
ricks2524's Avatar
ricks2524
Default Quick question on Tach wiring
Where the best place to connect to the Tach signal wire. I have an 06 Deluxe EFI . Don't want to take any unnecessary chances. Thanks
Old Aug 19, 2020 | 06:34 PM
Dallas 13's Avatar
Dallas 13
Need some more info: was the tach stock, or add on; guessing you have the 88 TC? Do you have the service manual?
Old Aug 20, 2020 | 05:17 AM
ricks2524's Avatar
ricks2524
Its an add-on. My manual doesn't list a "signal" wire. I'm assuming it means a + connection, but want to make sure before I go further . Yellow/Black
Old Aug 23, 2020 | 10:56 PM
Max Headflow's Avatar
Max Headflow
The is a tach output on the ECM. Haven't tried using it tho..
Old Aug 28, 2020 | 08:14 PM
Zanthamos's Avatar
Zanthamos
Tach comes off ECM, that tach you have is an analog tach and incompatible with EFI bikes. You need one that will have a Y splitter from the speedo or get the HD speedo with a tach on it.
Old Aug 28, 2020 | 08:28 PM
Max Headflow
I think you are trying to say the Tach needs to interface to the serial bus to get RPMs.. As far as I can tell the 06 ECM still has a Tachometer output which should be 1 pulse per rev.
Old Aug 28, 2020 | 09:12 PM
Zanthamos's Avatar
Zanthamos
The tach signal is already at the speedo connector even though the wiring diagrams do not show a wire from the ECM pin 3 but it is a digital output signal not a ppm signal as you would get from the coil connection. There is not a good point to tie into the BE/O wire on the coil to get an analog tach signal.
Old Aug 28, 2020 | 10:00 PM
Max Headflow
Well, if that's the case the y cable to the coil primaries is the only answer for that tach.
Old Aug 29, 2020 | 05:28 AM
ricks2524's Avatar
ricks2524
I can make the splitter with a couple resistors and diodes. I will try the signal hook up qt the ECM.
Old Aug 29, 2020 | 11:12 AM
larsfum's Avatar
larsfum
The tach signal wire is usually pink if that helps.
Sal C
Aug 28, 2020 10:51 PM
drifter64
Apr 18, 2012 04:49 PM
bolillo57
Jan 31, 2011 12:25 AM
Beauregard
Jun 21, 2009 09:14 AM
dfb
Feb 18, 2008 04:03 PM
