[QUOTE=Dan89FLSTC;19467148]Maybe so, but he needs to be accurate in his questions, and put a bit of effort in to communicating.
Wow Dan.....thats a bit of a statement.
Firstly I am not from the USA i am from across the pond where we dont call indicators passing lights. So my mistake. We have indicators on both the front and the rear. So what do you call the indicators on the back of the bike if they are not passing lights. Seems logical to me but what do I know.
After some further research I have solved the wiring problem.
The Tombstone rear light assembly with indicators has One Red and One Black wire to each indicator. The indicator bulbs are dual filament. So meaning one part of the bulb blinks via the red wire and the other part is a running light via the black wire. We dont ever have that setup across here after 55 years of riding I have never come it before.
The Tail Light / Brake light combo again has one black and one red wire. The red is the brake light and the black is the running light. From the Harley Heritage FLSTC existing wiring harness I connected red to red and blue to black.
i daisy collected all the black running wires together and connected them to the blue wire from the harnes.
The Tombstone assembly needs to be earthed, so i chose back to the battery terminal.
Job done.
i thank you all for your help. I promise to try and communicate better in future Dan 😂
This type stuff is not the way to describe an issue.
Its very very unusual for any automotive light manufacturer to use black for anything else but ground (negative).
Unless the wires are going to be visible.
