Charging Voltage
Old Mar 9, 2021 | 06:25 PM
Rogue8Man's Avatar
Rogue8Man
Default Charging Voltage
Good evening. I ride a 2011 FLHTC. It has a Cycle Electric stator and voltage regulator. My question is: I read the bike should be putting out 14.3-14.8 volts @75*F and 3600 rpms. Will this voltage go down slightly when the temperature dips into the low 60’s and below?
TIA
RogueMan
Old Mar 9, 2021 | 06:36 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I doubt temperature will affect it a lot. Maybe some but when it warms up running, it's still pretty warm. With a charged battery and the lights on, most run there. I bet if you could kill lights, it would drop to 13.5 or so.
Test rpm for stock is 2000. But modern Harleys' are all in by 1500 or so. What you see after that is regulator control depending on battery charge.
Old Mar 10, 2021 | 04:20 AM
Rogue8Man's Avatar
Rogue8Man
Thanks for the reply. I’ll watch it. I think I am being paranoid. Leaving for Daytona min a few mins so if it doesn’t work out I’ll sort it out. Starts and runs fine. No codes. I was just watching the values thru the FuelPack app and thought it strange.
Old Mar 10, 2021 | 06:43 AM
Jackie Paper
If it's below 15 and at least a little above 12.8 all is good.
Harley put a light on oil and charge for a reason. They don't want you paranoid. It's those tin men who keep the paranoia alive.
Old Mar 10, 2021 | 09:07 AM
Zanthamos's Avatar
Zanthamos
So it's the Cybermen who keep the paranoia alive?
Old Mar 10, 2021 | 09:14 AM
Jackie Paper
Na..they r not real.
Jeremyc482
Aug 5, 2019 03:50 AM
Goose_NC
Electrical/Lighting/Alarm
19
Aug 13, 2018 03:24 AM
Bluraven
Oct 6, 2016 07:53 PM
QehQeh
Dec 26, 2013 05:41 PM
murf1
EVO
May 30, 2009 09:25 PM
