tripping circuit breaker
Old May 11, 2022 | 11:35 PM
yomikey's Avatar
yomikey
Stage II
Default tripping circuit breaker
So I got a 94 heritage soft tail. its my daily rider. one day went to work came home and it was good no problems. the next day I got to start it and batt. is completely dead. i pulled out battery and charged it overnight. The next day i go to hook up batt and as soon as I hook up the last batt terminal the circuit breaker trips right away. ignition switch is in off position... any ideas? switch ,starter, or just a hot wire that grounded?
Old May 12, 2022 | 03:33 AM
Jackie Paper's Avatar
Jackie Paper
Take the battery out and have it checked a good trusted auto parts store. Since your battery was working OK, it's possible it shorted inside.
Start there. Keep it simple first. Then we will go deep
PS. Make your next new post over in the new member area. Just in case..
Welcome from North Beach, FL., USA!
Just in case you have not done this.
Add a Signature Line in your USER set up for your bike year, model, and all the letters that Harley recognizes it with so others see at the bottom of all your post. This enables others to know your exact model if you ever ask a question.
And an Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post.
​​Your all set.... Enjoy the ride! ______________
Old May 12, 2022 | 05:41 AM
kel03's Avatar
kel03
Old May 12, 2022 | 05:52 AM
IronAss's Avatar
IronAss
I know about as much about electrical problems as I do women but it sounds to me like possibly the battery hot lead is grounding. Possibly a split in the insulation jumping to the frame?
Old May 12, 2022 | 06:27 AM
Spartanden's Avatar
Spartanden
Good Luck!!
Old May 12, 2022 | 07:45 AM
squirrelsnest's Avatar
squirrelsnest
Welcome to the forums from Virginia.............
Old May 12, 2022 | 08:23 AM
bustert's Avatar
bustert
wiring schematic is your friend. power source is not all routed through the ign switch.
typically battery cable goes to the starter terminal where it is tapped off to go to the system so there is an issue in wiring.
in electronics we say divide and conquer, so remove tap for system from starter post and the reconnect battery, if all is well then you have a direction you must travel.
before you touch the terminal, look closely to see if there is a short there, aka, cable termination touching the starter case.
if it is the power cable side, replace with welding whip lead, way softer than original and give you some extra length to easy service.
Old May 12, 2022 | 10:32 AM
yomikey's Avatar
yomikey
Stage II
its a new battery about a month old. But load tested anyway and its good to go
Old May 12, 2022 | 12:41 PM
critter85's Avatar
critter85
Welcome to the Forum lots of good information here
Old May 13, 2022 | 06:44 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the main breaker trips as soon as you connect the battery, it is telling you there is a short to ground (a bad battery is not going to cause a circuit breaker to trip).
The short could be anywhere between the main breaker and the three 15Amp breakers, or between the main breaker and the voltage regulator.
You are going to have to pull the seat and fuel tank and look at the wires.
Look at the wire that runs from the main breaker up to the ignition switch (tan wire).
Check the wire that runs from the main breaker to the voltage regulator.
Check the wires that run from the ignition switch to each breaker copper stud.
SugsPa
Jun 2, 2017 08:21 AM
bkbroiler
Electrical/Lighting/Alarm
11
Oct 20, 2015 07:52 PM
Brick0044
Aug 5, 2013 12:56 PM
HD_Patriot
Apr 26, 2012 11:22 PM
calebv
Dec 5, 2008 10:42 PM
