no lights
Old Mar 13, 2023 | 07:36 PM
willybsure's Avatar
willybsure
5th Gear
Default no lights
just getting bike out 2013 road glide custom low beam lights work but no high beams and no high beam indicater light .. checked voltage at headlight plug have 12 volts on low beams but no voltage on high beam side when switch is on high beam
Old Mar 13, 2023 | 11:12 PM
NODYNA's Avatar
NODYNA
Check the input and output of the switch for voltage to start narrowing down the cause.
Old Mar 14, 2023 | 05:24 PM
willybsure's Avatar
willybsure
5th Gear
gotcha just pulled switch apart have 12 coming in on blue wire and power going out to white on high beam and to yellow on low beam just had fairing off this weekend to install new soundigital amp so i guess fairing is coming back off to find out what i pulled apart ugh .. im sure you know how fun that fairing is to pull off and reinstall 2013 road glide .. well at least now i know where the problem is thanks for ur direction
Old Mar 15, 2023 | 07:42 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Check the connector that connects the switch harness to the fairing harness, look for a damaged pin, or a pin/socket that has been pushed back.
GuamRider
Dec 21, 2022 08:15 AM
cannot
Jul 22, 2021 07:57 AM
cnnesseth
May 4, 2013 09:24 PM
chateau
Oct 5, 2011 11:07 PM
Matt0987
Jun 20, 2011 12:04 AM
