2002 electraglide issues
Old Jun 8, 2025 | 07:55 PM
psimpson's Avatar
psimpson
Stage IV
Default 2002 electraglide issues
As the title says my 2002 Electra Glide has started to turn off after about 40 minutes of riding. This started happening maybe 2-3 months ago. It turns off, but the headlights and dash lights stay on and after a minute I can start it right up and ride another 40 minutes. I replaced the battery (needed to anyways) and same issue. made sure the connections to the battery were tight. Starts right up in the beginning but gives me a little fight when starting up after it dies.
I'm going to check the coil and use a multimeter to follow the cables that are coming from the battery, but anything else I should check?
Old Jun 9, 2025 | 01:39 PM
Max Headflow's Avatar
Max Headflow
Gas Cap vent.
Fuel flow to the carb.
Crank sensor AC voltage while cranking. Should be above 3 volts.
Old Jun 9, 2025 | 06:51 PM
psimpson's Avatar
psimpson
Stage IV
Gas Cap vent.
ill add those to the list of things to check and let you all know thank you.
wtlawson8
Electrical/Lighting/Alarm
Sep 23, 2022 09:08 PM
apetterez
Sep 14, 2014 09:43 PM
BadMetal705
Dec 23, 2011 02:18 AM
13point
May 31, 2010 04:24 PM
b5mac
Feb 2, 2008 11:03 PM
