Low compression issue
Old Jan 14, 2015 | 02:15 AM
ridedaddy's Avatar
ridedaddy
Feels good to be right for once.... Lol glad you found the issue!
Old Jan 14, 2015 | 05:57 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Now it'll run like it is supposed to.
Seat-of-the-pants smoother as well.
Scott
Old Jan 14, 2015 | 09:40 AM
djl's Avatar
djl
Glad you solve the problem. I miss read your OP and assumed that the 26 cams had 75K miles on them and the low compression was a new issue. Good catch by ridedaddy on the cam timing. Get that carb tuned and you are off and running.
Old Jan 14, 2015 | 10:53 AM
kkiley's Avatar
kkiley
The difference is amazing. The mid range is kicking the butt dyno hard now. It had 46 pilot and 185 main in it and it felt a little lean climbing up, so I put the 200 main back in it for now. Got rid of the lean feeling and I can tune it from there.
Thanks again!
Old Jan 14, 2015 | 11:20 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default good for you......
I'm glad to here it was as simple as that. Bright side is a Fresh ring job. Ride happy.....
Old Jan 14, 2015 | 12:54 PM
djl's Avatar
djl
Thanks again!
Work the needle; you can be spot on at WOT but lean at partial throttle which you don't want. Anyway you can get it on a dyno to check AFR at partial throttle? I am betting that the needle might need shimming a bit and with the needle shimmed, you might be able to drop back to a 190 main; 200 main sounds a bit fat for a Stage I TC88 with mouse cams. JMHO.
mikmor68
Apr 12, 2013 04:19 PM
mikmor68
Exhaust System Topics
Mar 11, 2013 09:20 AM
N-gin
Mar 24, 2011 04:24 PM
qtrracer
Sep 10, 2010 11:34 AM
jlb0038
Jul 31, 2010 04:39 PM
