Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So sorry to post this I'm sure it's been beaten to death, however... I have a 04' Road King Custom with FI which I have converted to a bagger. It has 40K miles on it now with Stage 2 tuning.
I would like to perform the upgrade to the cam chain tensioners. Probably the Screamin Eagle hydraulic adjustor upgrade with the better oil pump. Would do the S&S gear drive update but I'm not sure the pinion gear will be within suggested .003 runout, but I will consider if it is.
Does anyone know of a shop that will discount the Screamin Eagle parts? Any suggestions would be appreciated.
If you have bought the bike recently I suggest you take a look inside the timing chest first. It is not uncommon to find that a PO has already made changes in there!
As for discounts, the dealers Stiggy mentions are regular on-line discounters, however come winter some local dealers offer discounts on occasions, so it would be worth asking around.
