Cam Tensioner Upgrade 95"
Old Mar 24, 2015 | 07:39 PM
fboy319's Avatar
fboy319
Default Cam Tensioner Upgrade 95"
I had a Stage 2 95" kit installed in my Wife's 03 Springer around 2009 50,000k it now has 85,000k and I want to upgrade the tensioner. It has SE2 cam's in it now and the question is while it's apart should I upgrade to different cam's or leave it be? Should I do the heads or leave them be and go with adjustable push rods? She's not hard on the bike basically a cruiser. Thanks
Old Mar 24, 2015 | 11:01 PM
dynawg1's Avatar
dynawg1
If she is happy with the way the bike runs, why borrow trouble by giving her the fever.
Old Mar 24, 2015 | 11:25 PM
PTSDBob's Avatar
PTSDBob
Default well ……..
While you are in there, I would upgrade to adjustable pushrods.. put in a new set of lifters… no need to change the cam if all is okay… maybe put in a new 'lefty bearing' if hp/tq upgrades are in your future.
Old Mar 25, 2015 | 01:56 PM
djl's Avatar
djl
What is the SE2 cam; not familiar with that one? Definitely replace the tensioners; suggest the CYCO tensioner for the replacement. I see no reason to upgrade to adjustable pushrods; just another piece of hardware that has the potential to cause problems so if you don't NEED them, why bother? At 85K miles, I would suggest having the heads worked with a simple "street" port that is offered by several porters for $400-$450. At 86K miles it would be a good time for a valve job, new guide seals and shave .020"-.030" or so off the heads for a mild compression bump. If the inner cam bearings were not upgraded with the big bore kit install, it would be a good time to upgrade them as well. If the wife is happy with way the bike runs, why change cams? I would invest the money in the heads and a little more compression for a mild boost in performance and call it good.
Old Mar 26, 2015 | 05:46 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Darn good advice.
Scott
Old Apr 14, 2015 | 02:40 PM
fboy319's Avatar
fboy319
Should be se203
pegskraper
Engine Mechanical Topics
Oct 29, 2016 10:22 PM
1sweetglide08
Jan 10, 2010 11:13 PM
BadPiggy
Jan 19, 2009 04:35 PM
expolice
Exhaust System Topics
Oct 9, 2008 08:06 AM
O5HOG
Nov 15, 2005 11:04 AM
