2008 Road King power
Old Jun 24, 2015 | 02:00 AM
groesener's Avatar
groesener
2nd Gear
Default 2008 Road King power
Greetings, all.
I bought my '08 Road King 4 years ago after the demise of my FXR while on a cross-country road trip. The bike had 32K on it, it now has 120K.
Obviously, overall I love the bike. But its engine is getting long in the tooth, and I'm thinking a little pre-emptive work now might save me the trauma of the FXR's experience of dying The Death while on the road.
1. I weigh a solid 275lbs, and travel with a lot of camera gear (photos.themightyviking.com, if you're interested)
2. On hills, and at the moment of passing a car, the bike seems a bit sluggish and weak.
3. I want to be able to mount up a sidecar for my disabled son and toddle the local roads.
4. I plan to install a Baker kit in the transmission
5. My bike already has the stage one chip, and air intake.
6. I plan to get a Kuriakyn Hypercharger intake, and am already running Bassani true dual exhaust.
7. I'm hearing some new noises recently that I don't know enough to identify. when I get off the throttle, after a moment's delay the engine sheds a couple-second long sound that is similar to a cookie sheet full of washers being shaken.
As near as I can tell, aside from the stage 1 intake and chip, I have a stock 96ci. My intention is to take a hard look at cams and lifters. I don't mind a rough idle if it will help me for my usage, the main thing is I want to boost power from the inside out so I don't have to struggle on hills (I spend a decent amount of time in some tall mountain ranges with long grades) or with passing going from 5th gear to 6th, starting at 65-70 and accelerating.
I'd like to be able to learn enough to do most of the work myself, and to speak intelligently to a mechanic/tuner if I wind up needing one.
With all this in mind, what cam/lifter modifications come to mind? Is there anything else I can do that I'm not thinking of, as I start the tuning process?
Old Jun 24, 2015 | 06:21 AM
filtrod's Avatar
filtrod
Have a 2007 Road King and I replaced the factory engine with a S&S 124 now I have all the power I care to dial in. Took a little while to get it tuned right but happy I did the swap, Good Luck
Old Jun 24, 2015 | 06:38 AM
filtrod's Avatar
filtrod
Default 2007 Engine
You can call Kurt at the Bike Shop in Lafayette Louisiana 337-504-3371. I feel he is honest and a straight shooter
Glen
Old Jun 24, 2015 | 07:53 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Originally Posted by groesener
Greetings, all.
Bore to 107"
Andrews 57 cams
S&S lifters/pushrods
Our Stage I Heads
Bore/port t/body to 50 mm
Easy bolt togather process, as we have all the homework done for you
Tune it and smile.
Scott
Old Jun 24, 2015 | 07:56 AM
dsvracer1's Avatar
dsvracer1
5th Gear
IMO i would forget about a six speed. if you are having problems passing or going up hills in 5th gear then going to 6th gear will make the problem worst.
The higher the gear ratio and the lower the rpms the less power you will make. i would suggest that you bore out the cylinder to a 103 or even a 107. this is the cheapest power you can get, more displacement. If you want even more then i would do the heads and a better cam. there are plenty of questions to ask before you get started on this project. i can help.
thanks dsv
Old Jun 24, 2015 | 12:24 PM
groesener's Avatar
groesener
2nd Gear
Filtrod: Does that S&S retain the fuel injection, or is it carbureted? 127? Seriously? Good god... How does it do in gas mileage?
Hillsidecyclecom: 107"? Dang, way to turn my six-shooter into an elephant gun! hadn't really thought about anything but cam and other minor non-machining changes. Going bigger does sound fun though.
Old Jun 24, 2015 | 12:32 PM
Hillsidecycle.com
Sponsor
No big gun, or hot-rod whatsoever, just a big broad torque curve that comes on early, and carrys.
Plug/play cam-only set up?
Andrews 48's.
Scott
Old Jun 24, 2015 | 12:49 PM
groesener's Avatar
groesener
2nd Gear
I see the TW48 listed at JP Cycle. That one? I'm a little out of range of Munnsville NY, sadly, being in Oregon. Otherwise would love to sit on a stump and look this over with you. Thanks.
Old Jun 24, 2015 | 01:41 PM
Hillsidecycle.com
Sponsor
JP Cycles???????
We have all on the shelf 24/7 to facilitate an easy install.........and ship Fed-Ex daily........
Old Jun 24, 2015 | 07:50 PM
dynawg1's Avatar
dynawg1
Listen to Scott and whatever you do skip the HyperCharger. Biggest waste of money ever.
Rich_rider27
Engine Mechanical Topics
Sep 2, 2014 10:07 AM
jcs7scpa
Exhaust System Topics
Dec 19, 2008 12:56 PM
gunnert
Dec 15, 2008 07:13 PM
onthedish1
Feb 1, 2007 04:46 PM
rkchd
Dec 18, 2005 05:35 PM
