Se203
Old Dec 12, 2016 | 06:34 PM
HDSAE60's Avatar
HDSAE60
Default Se203
I had a TC88 with SE203 cams and really liked the sound at idle and the power. Now I have a 103 with Woods 222 cams and I'm thinking about the stage IV 110 kit. Will any SE cam have the sound at idle and power bump like the 88 with the 203? The 103 was a joke stock, and not much better with the woods 222. I really want to get it right this time.
Old Dec 13, 2016 | 06:13 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Besides doing the cam on the 103, did you do anything else to the motor. Bump in comp or anything? What were the numbers on that combination?
Old Dec 13, 2016 | 06:41 AM
HDSAE60's Avatar
HDSAE60
Just a HF air filter, Super tuner, decat the head pipe and some Rinehart 4" slip on pipes.
Old Dec 13, 2016 | 07:57 PM
98hotrodfatboy
Can you tell me what the numbers were for the 103 w/222 cams?
Old Dec 14, 2016 | 12:32 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
S&S .570.
Scott
Old Dec 14, 2016 | 02:15 PM
djl's Avatar
djl
Too much compression with 203 in a 110 configuration. The naysayers will weigh in but the SE259 would work as would TMan 590.
Old Dec 14, 2016 | 10:28 PM
HDSAE60's Avatar
HDSAE60
Originally Posted by Hillsidecycle.com
S&S .570.
Scott
So you think the .570" would sound and perform like the 203/TC88, if used with the 110 kit 92500037A? What is your opinion of the SE-585 with the 110 kit?
Old Dec 15, 2016 | 03:44 AM
Hillsidecycle.com
Sponsor
The .585 is a low-mid power oriented cam as what we've seen on our dyno, and will carry more ccp that the .570.
The .570 will have that "lope" your looking for, and far out-perform the 230/88" combination.
10.2 cr is where we cap that.
Scott
Old Dec 30, 2016 | 11:17 AM
HDSAE60's Avatar
HDSAE60
Scott
Thanks Scott! Will the pushrods for the 259e cam that come in the kit (92500037A) work with the .570 cam?
Old Jan 2, 2017 | 07:00 AM
Tn.Heritage's Avatar
Tn.Heritage
You will have the lope you want with the 259e but the comp will be better set at 10.8 or so with that cam. Go to J&B Performance FB page and here a 117" kit with the 259's installed, there in a 2016 RG.
