Se203
Old Jun 28, 2017 | 10:27 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by HDSAE60
Remember me? I tried the S&S 570 cams like you said, but it didn't have the low rpm torque I was looking for. Can you suggest something with a lot of low end grunt? I ride two up and in the mountains most of the time. Bike is a Ultralimited with a 110"/ SE pro ported heads 58mm TB.
Did you ever post a Dyno sheet?
Old Jun 29, 2017 | 04:17 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What is the actual compression of that engine?
Thought you were looking for the "sound"?
The S&S .570 set at 10.2 cr should have good snap in a 110".
Done enough to know.
Scott
Old Jun 29, 2017 | 06:02 AM
Xpressway's Avatar
Xpressway
Scott
My 110 is set up like Scott says, and it's everything I expected. Lopey, torquey and less heat. I enjoy it no matter what gear I'm in. Tuning for this cam is key tho.
Old Jun 29, 2017 | 11:18 AM
HDSAE60's Avatar
HDSAE60
It does sound good and has snap going through the gears but it just doesnt hold 6th very well at 70 pulling hills. Its my own fault for worring about the sound
Old Jun 29, 2017 | 11:21 AM
HDSAE60's Avatar
HDSAE60
the tune came from FuelMoto. PV with target tune
Old Jun 29, 2017 | 12:34 PM
Fat11Lo's Avatar
Fat11Lo
Ever thought about pulley swap or a Rivera Primo Game Changer, if you're doing a lot of mountain riding then a gearing change would be a lot more bang for the buck
Old Jun 29, 2017 | 01:05 PM
Fat11Lo's Avatar
Fat11Lo
Even FM will tell you their tunes are a starting point.
There is NO substitute for a proper dyno tune, and target tune can only "hold" a tune if the map is not optimal for your bike target tune will not correct it, it will only hold the values in your map
Old Jun 29, 2017 | 06:48 PM
cdonis's Avatar
cdonis
Better tune, use 5th gear pulling hills, especially on a bagger two up.
Old Jun 30, 2017 | 04:39 AM
Hillsidecycle.com
Sponsor
10.2 compression, and an actual tune.
Combination we build often.
Runs very well, but at 10.2, and with an actual tune in it.
Scott
Old Jul 1, 2017 | 10:43 AM
98hotrodfatboy
As stated by Fat11lo, get a dyno tune but before you do get rid of the 3.15:1 gear ratio... Not good to lug up hills.
Chadster21
Sep 30, 2015 12:33 AM
butch patrick
Dec 5, 2012 01:32 PM
FX4
May 15, 2011 07:59 AM
accura45
Feb 20, 2011 08:17 PM
SE120RG
Jun 23, 2010 08:50 AM
