Scott @ Hillsidecycle
Old Jan 2, 2017 | 05:34 PM
W.Glide's Avatar
W.Glide
Default Scott @ Hillsidecycle
Scott, i'd like your input. I'm considering changing cams only this next year on my '16 Wide Glide with a 103HO, and V&H 2into2 Big Radius pipes. The 2 different cams i'm looking at are S&S 583, and the 585. I'm not wanting to loose any bottom end over the stock cams, and would the S&S 585 keep my bottom end and give me a little more up top? It's a bone stock 103 except for the pipes and a tune. Thanks for your input.
Old Jan 3, 2017 | 12:47 AM
Arseclown's Avatar
Arseclown
Those two cams are very different. The 585 cam will be very soft down low with stock comp.
Old Jan 3, 2017 | 05:18 AM
ntraindavefl's Avatar
ntraindavefl
Plus you won't get much out the back door with any hp cam using stock heads.
If staying w S&S the best bet is the mr103 in stock application.
Old Jan 3, 2017 | 05:54 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Of those 2 cams, the .583 will suite your needs better, but Dave makes a good point as well.
Scott
Old Jan 3, 2017 | 06:56 AM
prodrag1320's Avatar
prodrag1320
common mistake we get all the time from riders.the 583`s & 585`s are two completely different cams.while the 583`s are very nice for low & midrange at moderate compression (we set them @ 9.8-1),the 585`s are more of a hotrod,high RPM cam with compression set at a minimum of 10.5-1.
Old Jan 3, 2017 | 06:00 PM
W.Glide's Avatar
W.Glide
Thank you to ALL of you guys that replied!! I really appreciate all the info I received, and when I went back and reviewed the info on the 585's, well let's just say I may have had 1 to many when I read S&S's info. Like Dave said the MR103 looks a lot more like what i'm after. Is there another brand of cams and specific part # any of you guys would suggest over the S&S 583 or MR103 on a bone stock 103 other than pipes? If not, would the 583 or MR103 be the best? Thank you guys again for your input.
Old Jan 4, 2017 | 12:09 AM
wickerham's Avatar
wickerham
Andrews 57 or SE 204
The SE 204 will give ya that badass, nasty idle
Old Jan 5, 2017 | 06:26 AM
grbrown's Avatar
grbrown
Cool
Excuse me if I have a chuckle at that! My S&S V107T Evo came stock with a 585 and CR of 9.5:1. Pulls like a freight train with a wide flat torque curve and is a great ride. I'm sure you chaps could wake it up a lot more, but with the Atlantic in the way it will have to stay as it is.
Old Jan 5, 2017 | 06:52 AM
prodrag1320
chuckle all ya want pal.585 cams set at 9.5-1 will be flat as hell,REALLY flat on the bottom and with compression that low,wont make any real power in higher RPM`s either. try bumping the compression up to 10.5-1.im sure S&S has the compression that low for EPA regs
Old Jan 5, 2017 | 08:04 AM
grbrown's Avatar
grbrown
Wink
Well it ain't that flat, which is the point I'm making! And it isn't an EPA engine.
