98" big bore
Old Mar 7, 2017 | 05:58 PM
Dwaters's Avatar
Dwaters
Default 98" big bore
Scott from hillside cycles done a awesome job on everything I needed for my big bore kit with his stage 1 heads. I already had andrews 26 cams and a dragos dragula 2 2/1 exhaust. I had it dynoed at ray price in Raleigh Nc. The bike runs great but every now and then on cold start up I get a back fire. I kinda feel like it's running a little rich. Here is my dyno sheet. Do you think a new tune from somewhere else get more out of it then this and any idea on the backfire.
Old Mar 7, 2017 | 06:06 PM
QC's Avatar
QC
Quite the dip in the torque curve.
I would bring it back to the guy that did the tune and ask him to fix your backfire issue. He should back his work.
Old Mar 7, 2017 | 06:24 PM
Dwaters's Avatar
Dwaters
Any idea on the dip in the torque curve
Old Mar 7, 2017 | 06:34 PM
QC's Avatar
QC
Do you have any baffles in the pipe?
Old Mar 7, 2017 | 06:36 PM
Dwaters's Avatar
Dwaters
Yes have 2.5" baffles
Old Mar 7, 2017 | 06:43 PM
QC's Avatar
QC
A backfire when cold is usually a lean issue. Check to make sure you don't have an exhaust leak at the head where the pipe goes in. That could cause your backfire issue, too.
Old Mar 7, 2017 | 06:45 PM
Dwaters's Avatar
Dwaters
I'll check that. Thanks for the info
Old Mar 7, 2017 | 06:47 PM
QC's Avatar
QC
Sure. I'm no expert on this stuff.
Others in here know far more than me.
The numbers look ok for that cam actually, but that dip is unusual for a 26 since it is pretty much a lower end cam.
Old Mar 7, 2017 | 06:51 PM
QC's Avatar
QC
here is a link to another thread on your pipe. Maybe this will help you figure your issue out.
https://www.google.com/url?sa=t&rct=...npePPzgQKJzgIw
Old Mar 7, 2017 | 07:06 PM
Dwaters's Avatar
Dwaters
Thanks for the link I have the 2.55 baffles not the 2.50. Somethings going on just need opinions.
