View Poll Results: Which cam for low end torque?
Andrews 48
34.85%
Cyclerama 570
9.85%
Woods 222
14.39%
Woods 555
6.06%
Woods 777
3.03%
TMan 555
6.82%
TTS-100
10.61%
SE204
5.30%
SE259
3.79%
S&S 570
7.58%
Multiple Choice Poll. Voters: 132. You may not vote on this poll
Cam poll: best low to mid torque
Old Apr 1, 2017 | 08:05 AM
  #31
djl's Avatar
djl
Originally Posted by Bafflingbs
I didn't list the 255 because, isn't that what I basically have now?
Yes; I missed the model year in your OP. That year did offer the HO103 and the cams had a very similar profile to the 255, so you are correct; not much to be gained. But the other cams referenced in my last post would provide a measurable difference in performance; the TTS cams will wake that puppy up.
Old Apr 2, 2017 | 08:21 AM
  #32
Bafflingbs's Avatar
Bafflingbs
I honestly expected a better turn out for this poll. I also didn't see the Andrews 48 doing as well as it is. I thought most would side with Woods. Don't get me wrong, I love Andrews, and from what I know, they play a major roll in grinding other manufacturers cams. The TTS-100 and Cyclerama's 555 is where I lean, because they give more room for growth, while still working well in stock configuration. I also like the 222's and 555's. But, I love how inexpensive the Andrews are.
Old Apr 2, 2017 | 04:02 PM
  #33
misfitJason's Avatar
misfitJason
Tts 100 or andrews 48h are great cams for relatively stock motors that would be great bolt ins
Old Apr 2, 2017 | 05:49 PM
  #34
djl's Avatar
djl
Define "room for growth"; not sure I agree on the concept of selecting a cam and assuming it will work just as well in a more modified configuration. I subscribe to the "select the cam and build around it" formula.
Old Apr 2, 2017 | 06:31 PM
  #35
dfwhockey17's Avatar
dfwhockey17
Originally Posted by ntraindavefl
And I say this with no pleasure in promoting this company
Why do you say this?
Old Apr 2, 2017 | 07:23 PM
  #36
Bafflingbs's Avatar
Bafflingbs
Ported and polished heads
Old Apr 3, 2017 | 06:05 PM
  #37
Fat11Lo's Avatar
Fat11Lo
I was wondering the same thing????
Old Apr 5, 2017 | 08:03 PM
  #38
Marty33's Avatar
Marty33
For a heavy bagger check out the S&S 551 cams.
Old Apr 5, 2017 | 09:02 PM
  #39
martinj's Avatar
martinj
I would suggest that there are some cams that can very successfully be built around in stages. The CR575 is a good example, it's a pretty solid upgrade as a bolt in for a 103. Add ported heads, compression, and more cubic inches in just about any order or combination and it just keeps getting better and better. For a bolt in cam only with no other planned upgrades, there are obviously better choices though, the 570 coming handily to mind.
Disclaimer: Obviously there are a lot of cams out there that this strategy will NOT work well with. Let the buyer beware.....
Old Apr 5, 2017 | 11:50 PM
  #40
Bafflingbs's Avatar
Bafflingbs
Trying to decide if I want to just do the cams, (222's) or do FM 107" kit. I know how you guys will side, but, I'm on a limited budget, cause I want to do other things. ie.) wheels and rear CVO fender. All choices are stupid expensive! That's why, I wanted to future proof the cam choice. I'm leaning towards just the cams, cause all I really want, is more power upon take off. The 222's promise to deliver exactly what I want. I see that my poll is favoring the Andrews. Don't get me wrong, I like Andrews. My '03 Road King had a 95" big bore and Andrews 26's, and that thing was a beast! Why is everyone siding with the 48's over the Trip. 2's? Cost? Performance? Or, a little of both? If both were the same price, which one then?
Another question I have, and it's kind of important, do I need adjustable push rods and roller tappets? Or will the stock ones be fine? In other words, what else do I need to buy for just doing cams?
