2010 Wide Glide front engine oil leak?
Old Apr 19, 2017 | 06:18 PM
mshorsehand's Avatar
mshorsehand
Stage II
Default 2010 Wide Glide front engine oil leak?
Recently bought a 2010 wide glide only 6000 mi, after riding there is very clean oil misted on left front of engine and appears to be dripping from clutch cable adjustment boot. I understand it is a mechanical cable, I can find no visible leaks or weeping gaskets. Bike has sat for last 4 yrs, any one else seen this?
Old Apr 19, 2017 | 06:23 PM
cvaria's Avatar
cvaria
did you look at the fork seals and eliminate them as a source?
Old Apr 19, 2017 | 07:43 PM
mshorsehand
Stage II
Forks are clean and dry, looks like primary fluid but can't locate source, n never seen oil blow forward. Guess its time to change fluids and measure in and then out.
Old Apr 20, 2017 | 09:29 AM
angelrod's Avatar
angelrod
it could be oil from your cable itself . i over lube mine and it drips down to the adjuster
dkleiner
Dec 17, 2018 02:12 PM
flopper
Jul 14, 2015 05:28 PM
twistedcherokee
Oct 31, 2010 05:49 PM
zwrightwideglide
Jul 9, 2010 03:50 PM
bescaes
Oct 28, 2008 09:27 AM
