EVO identification #
Old Aug 2, 2017 | 07:58 PM
14GuineaPig's Avatar
14GuineaPig
Originally Posted by Sactown K
Can anyone help me out with identifying these two motors?
The eng. ID for the one I'm running is *DPLR504673*
The eng. ID for the boxed motor is *DDV2634749*
Any help is greatly appreciated.
DPLR = 1994 FLHTC Ultra 80" Evo Carb
DDV2 = 2002 FLHT 88" Twin Cam Carb
Old Aug 2, 2017 | 11:16 PM
Sactown K's Avatar
Sactown K
5th Gear
Thanks!!
Old Aug 3, 2017 | 04:08 AM
grbrown's Avatar
grbrown
Thumbs up
Well done - where did you find the year info?
Old Aug 3, 2017 | 06:48 AM
14GuineaPig
Old Aug 14, 2023 | 09:42 AM
vintageironrider's Avatar
vintageironrider
Stage II
Default Same issue here
Originally Posted by papajoe8
I have a chopper with an EVO engine there are no markings on the engine except a vin # on the left case below and center of cylinder base surface normal HD spot but the number don't look like a HD number can anyone help me find out what I have, the # is *BKLX928670* the chopper is titled as 2002 if that helps
I am having the same issue with BKL X923079 in an unstamped rigid frame being sold as a 1984 Harley Custom and no luck with the Texas assigned vin tag on the frame neck
Old Aug 14, 2023 | 09:44 AM
vintageironrider
Stage II
Old Aug 14, 2023 | 11:49 AM
t150vej's Avatar
t150vej
BK - FXSTC
L - 1340 EVO
X - 1999
That's the engine.
The assigned number on the neck is irrelevant to the hardware. Legal VIN numbers are frame numbers only in most, if not all states since the early '70s.
Old Aug 14, 2023 | 03:39 PM
smitty901's Avatar
smitty901
Originally Posted by t150vej
BK - FXSTC
L - 1340 EVO
X - 1999
That's the engine.
There you go. The engine number is part of the Bikes VIN number it came off of.
Both Engine numbers post look legit for HD engine numbers from the time frame. If you post pictures of the Number we most likely can tell if it is legit or a restamp. Things they did with style of letters and numbers most often give it away.
strange1
Engine Mechanical Topics
Oct 20, 2025 08:21 AM
fame2
EVO
Apr 27, 2014 08:14 AM
Chris Sconnie Besson
Apr 12, 2014 10:03 AM
mrsmartass2003
Custom Models
Jul 4, 2012 07:58 AM
harleydude68
Apr 13, 2008 03:27 PM
