117"
Old Jun 17, 2017 | 09:16 AM
Reindeer's Avatar
Reindeer
Originally Posted by Hillsidecycle.com
2 different builds.
If you are looking for more power, Larry can surely hook you up.
Scott
I understand 2 different builds, mine met/exceeded my goals. I'm definitely not looking for more power. My post wasn't intended to complain about the power difference between my setup and yours.
I'm mainly just curious on the advantages of the 110 head over the 96/103 head.
Old Jun 17, 2017 | 09:36 AM
cdonis's Avatar
cdonis
Reindeer, you did a great job with your build. I'm going to go with a run of the mill 124, 585 cams, and S&S heads that come with the kit. 58 mm to feed it. Motor is out of the bike now and disassembled. Run out was way out on the stock crank at under 30000 miles. Enjoy your new power plant!
Old Jun 17, 2017 | 11:39 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A CVO 110" head has a larger valve/seat/throat/bowl than an OE casting, generally resulting in more air flow.
Larry Yacko, can fill you in on all the particulars, as he has a very good cylinder head program/methods, and consider him a friend of ours, as well.
Scott
Old Jun 20, 2017 | 12:10 PM
edtekk's Avatar
edtekk
Default 117"
This is my engine build. Had another builder do a 117" build last summer. That motor never met my expectations. Low dyno numbers and didn't hit hard on the low end like I wanted. After a few tunes from different tuners trying to find some more power to no avail the motor was an under achiever. Brought it to Hillside and let Scott do his thing. Man knows how to build a motor. Went with Scott's 110 CVO heads and different pistons and a few of his tricks and bike runs great. Do not doubt his knowledge. The man knows how to make power. Difference in power is quite noticable. Scott builds a better engine.Fact!
Old Jun 21, 2017 | 06:16 AM
Hillsidecycle.com
Sponsor
Thanks for the kind words Ed.
Glad you are happy with that!!
Scott
Aggressor05
Screamin Eagle CVO Models
Feb 23, 2016 11:15 AM
patrick74
Dec 13, 2015 07:43 PM
whetsel.m
Exhaust System Topics
Apr 28, 2009 12:45 PM
Gutman
Jul 17, 2008 06:38 PM
Bannana Boat
Feb 16, 2006 12:05 PM
