Time to upgrade my 103ho
Old Aug 18, 2017 | 10:12 AM
Fat11Lo's Avatar
Fat11Lo
Originally Posted by Tedwilliams09
DJL. I agree 100 % if funds are tight don't chase the big kit. It gets expensive fast. And if you are going to.. do your research.
Agree 100% Seems like a good rule of thumb to just take your engine parts quote and double it. At least it was in my case. By the time you add up all the little extras along the way, add in money for the tune and tuner if you don't already have one, and in my case my exhaust wouldn't support my build. The "oh, that's not bad for that kind of power increase" turns into "oh S#*T, how did I spend that much money?"
Old Aug 18, 2017 | 11:51 AM
cdonis's Avatar
cdonis
Originally Posted by 94 ultra
Will that work with a Wethead 2016 Limited it has a little bit increased compression stock , like 10.2) ??
Thanks
Cr575
Old Aug 18, 2017 | 03:03 PM
94 ultra's Avatar
94 ultra
Thanks DJ
I had a set of 57s but I sold them
I am an Idiot
I Will probably just do the Big bang eventually
110 with Woods 777 and Heads
Old Aug 18, 2017 | 03:17 PM
94 ultra's Avatar
94 ultra
I think we would all like to know the specs on the CR 575
Old Aug 18, 2017 | 03:19 PM
94 ultra's Avatar
94 ultra
sorry to OP to Hi Jack the Thread
I m out
Old Aug 18, 2017 | 04:44 PM
bstorer's Avatar
bstorer
And... since I have the 3 years left on my 5 year extended warranty, I'm hoping that having an HD dealer do the work, the warranty will not be voided. Or will it be voided if I use anything other than the HD kit?
Anyone know?
(Is that laughing I hear????)
Old Aug 18, 2017 | 07:30 PM
Tedwilliams09's Avatar
Tedwilliams09
Anyone know?
That is the magical question that you need to ask your deale. My dealer knows Scott did my motor work.. they will warranty everything except what he touched... and I don't blame them for that.
why should they warranty someone else's work
Old Aug 18, 2017 | 11:55 PM
rhuff's Avatar
rhuff
Anyone know?
About a guarantee that if it's not all MoCo parts, it won't be covered. Even if it is, it likely won't be covered as it's after the fact. You have an extended service plan thru a 3rd party company. The MoCo does nothing more than sell it.
Old Aug 19, 2017 | 12:17 AM
bklynbob's Avatar
bklynbob
Originally Posted by cdonis
Cr575
Add a 31 tooth pulley and a real tune and you'll be good to go. You can always do heads or a 110 kit later.
Old Aug 19, 2017 | 08:28 AM
bstorer's Avatar
bstorer
Apparently I'm not able to send you a Private message here... I'd like to know more about what worked and what didn't on your 110 kit. I've got a call into Scott at Hillside. Can you say anything about whether the issue was simply knowledge of how to set it up, or if it was a difference in the components used?
