Thoughts on engine break in via Dyno
Old Aug 17, 2017 | 01:23 PM
robbyville's Avatar
robbyville
Default Thoughts on engine break in via Dyno
I'm sure there must be mixed opinions on this, but...
I recently completed installation of new cylinders and pistons going from a 103 to a 107. These are matched by the builder to his ported heads and cams that I installed last year.
My challenge frankly is that with the heat where I live I really haven't been riding. So it took me some time to even get a 30 mile ride in to seat the piston rings.
I've been planning a usual break in procedure with oil changes, etc. based on riding that's not happening and then after about 500 miles get the bike re-tuned which I'm hoping won't be too difficult since it was done after the head and cam install.
So all this said, are there risks associated if I simply went to my Dyno tuner and have him run the bike and tune even though I only have 50 miles on the new pistons and cylinders?
Thanks as always!
Old Aug 17, 2017 | 01:49 PM
98hotrodfatboy's Avatar
98hotrodfatboy
No, a good tuner knows the process... But I think your rings are pretty much already seated... So go for it...
Old Aug 17, 2017 | 07:51 PM
ntraindavefl's Avatar
ntraindavefl
Do you need to re tune from only adding 4 cubes? I've done this 103-107. Before and never considered spending on a new tune.
Old Aug 17, 2017 | 07:54 PM
eaglefan1's Avatar
eaglefan1
I had my guy break my 106 kit in on the dyno. After that a full tune. On the dyno they can control everything. Its not going to sit there idling, like in traffic, unless he wants it to. Controlled environment is why I chose the break in procedure on the dyno
Old Aug 17, 2017 | 08:12 PM
rhuff's Avatar
rhuff
I wouldn't have a new build broke in any other way. This of course is assuming the person running the dyno isn't an idiot. Lots of tuners, not a lot of good ones.
Old Aug 17, 2017 | 09:59 PM
robbyville's Avatar
robbyville
Thanks folks!
In regards to whether or not I need another tune after adding 4 cubes... I'd rather just do it, even if for my own edification.
And yes, my tuner is very good and conscientious
Old Aug 17, 2017 | 11:49 PM
cdonis's Avatar
cdonis
Mine is going to have about 50 miles on it and some dyno time before I pick it up . After I get some miles on it the final tune will be done.
Old Aug 18, 2017 | 07:06 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I agree.
Scott
Old Aug 18, 2017 | 07:35 AM
hrdtail78's Avatar
hrdtail78
My thoughts on this. Fuel isn't the only consideration. Doing nothing else besides going from 103 to 107. You added compression.
dbuzzell
Dec 6, 2016 08:02 AM
2mOOn
Sep 15, 2014 06:52 AM
2mOOn
Sep 8, 2014 07:25 PM
bbach
Oct 22, 2010 06:11 PM
Tltrump
Exhaust System Topics
Mar 20, 2008 05:27 AM
