Hydraulic Tensioner Upgrade Still The Way To Go?
So I was wondering if the hydraulic tensioner upgrade is still the right way to go or are there now better options?
The bike runs great and motor doesnt make any strange noises. Has Rinehart True Dual exhaust and K&N filter. Otherwise stock.
Thanks.
At 30k I developed a bottom gasket leak. When I had that fixed, I had Sauk Prairie HD install the SE Cam Chain tensioner and oil pump upgrade. Because they had to take the rocker boxes off anyway they were able to reuse my stock pushrods. While they were in there they replaced the inner Cam bearings with Torringtons.
Bike runs great, have 43k now.
There are many threads on here about gear versus hydraulic upgrade. And about different cams. I wouldn't change cams without riding your bike a few thousand miles first. I went with what the dealer recommended. I don't know much about gear drives.
1. Check crank run out and if less than .003", install a set of S&S 509 gear drive cams, retain the OEM cam plate and pump if both are in good condition and replace the inner cam bearings with a set of Torrington/Nachi B148s. American Classic Motors offers the 509 cams, complete gear drive setup, inner and outer cam bearings and cam cover gasket for $595 with free shipping. Add the Baisley pressure relief valve spring for about $12.
2. Replace the OEM tensioners with the CYCO tensioners, retain the OEM cam plate, replace inner and outer cam bearings, install the Baisley spring and the 509 cams. Cost would be about $330 for all (except CYCO tensioners) from Revzilla. CYCO tensioners selling on EBay for half the cost of the OEM replacements.
3. Replace the OEM cam plate with the SE Hybrid kit (PN 25284-11)which retains the OEM inner chain but includes billet cam plate and hi-capacity oil pump. Cam plate, oil pump, new outer roller chain and hydraulic tensioner, inner hydraulic tensioner on the OEM link chain runs about $430 from an online discount dealer, plus shipping. The cam set is going to run about $300.
Note I have not mentioned lifters or pushrods. If you pull the push rods from the top, you can reuse them; if you go the adjustable route, throw in another $150 for a set of SE Quick Install Tapered adjustable push rods (PN 18404-08). With only 21K miles on a set of the OEM "B" lifters, you can reuse them as well. However, if you choose to replace them, throw in another $125.
So, as you can see, it's a matter of how much you want to spend since all of the above will produce the same performance results. JHMO, which isn't worth much, but #2, plus the addition of a fuel management system and a dyno tune would be my choice.
Here's what i did on my '06.
Replaced cam support plate with '07 and up version, new '07 higher flow oil pump, and Andrews 21N cams. This method gets rid of both silent chains. I replaced inner cam bearings, and re-used the B lifters (13k on them) and kept stock pushrods. Also added rockouts and catch can.
Bike runs really well with 21 cams in it, runs cooler and smoother, mileage is about the same.
