Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
AFIK Power Vision is the only DIY tuner that offer a license program. $200 is the going rate, I purchased my license for our second bike from Fuel Moto and it came with a map. Not a perfect solution but on a budget you could get close enough to ride. I would plan to save up for a proper tune though.
The parts I bought have new lifters in them as well. The guy said Harley took the 103 apart when it rolled into their showroom floor. They look brand new.
I have a tfi tuner on now. It will adjust most parameters manually. I agree when I scrape some cash together a full Dyno and tune will be in order. I think I'll save up for some cams. Used if I can find them. Thanks everyone.
