feuling problem
Old Jan 11, 2018 | 06:20 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Not a big fan of those.
Scott
Old Feb 16, 2018 | 12:25 AM
Dan Tibi's Avatar
Dan Tibi
Stage III
this is how my oil is in the oil thank before engine start and after the engine is started..in a couple of seconds alot of bubbles.. could this be air or moisture ?
and i made a picture with my oil gauge too while the engine is running.
Attached Thumbnails feuling problem-20180215_170841.jpg   feuling problem-20180215_171235.jpg   feuling problem-20180215_171035.jpg
Old Feb 16, 2018 | 06:48 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
The bubbles are completely normal in a Harley. That is the oil being scavenged and pumped back in the sump or bag on a Softail. Moisture would be more in the form of milky after stirred. Unless of course you let it sit a long time and then it would be on bottom of the oil.
Transmission dip stick looks same way after running.
Old Feb 16, 2018 | 08:58 AM
Max Headflow's Avatar
Max Headflow
A point to remember is that there are 2 pumps in the motor. A feed pump and scavenge pump. Feed pump make pressure and feed the motor. The scavenge pump sucks the oil out of the motor. To ensure that there is always the right level of oil in the motor, the scavenge pump is larger than the feed pump.. As a result the scavenge pump can suck air besides oil. The bubbles you are seeing is the scavenge pump sucking air.. This is normal operation. The bubbles become less and less as the oil heats up.
It can be a little worse if the pump allows oil to flow into the motor when sitting as the oil get whipped up by the flywheels before getting pumped out. At lower levels this is considered normal also..
Old Feb 19, 2018 | 02:10 PM
Dan Tibi's Avatar
Dan Tibi
Stage III
thanks for your answers... and what are your thoughts about the feuling 4000 HP+ lifters ..? and using them with a 140"-145" preload..
ldhdrider
Oil Archive (no new posts)
Feb 9, 2023 01:18 PM
MN-Ultra
EVO
18
Jul 10, 2017 09:54 AM
rockstar
Aug 8, 2013 09:42 PM
Fatboy_JJ
EVO
May 9, 2010 03:51 PM
haynes
Exhaust System Topics
Mar 13, 2005 07:38 PM
