Winter Upgrade
Old Jan 12, 2018 | 03:52 PM
13glidestreet's Avatar
13glidestreet
Default Winter Upgrade
So the bike is dropped off ready to be torn apart. Doing the S&S 110 kit woth 585 cams and sending the heads to S&S to be done as well. Along with that doing bigger injectors, and locking clutch. Going to have the Vance and Hines 2-1-2 header with 4inch rineharts with the high flow performance baffles. I can’t wait to see what the final product is going to be. Definitely going to be a different animal from the 103. Any of you guys have a similar setup?
Old Jan 12, 2018 | 08:49 PM
Teardrop's Avatar
Teardrop
I had to get a new rear tire so I can continue riding.
Old Jan 13, 2018 | 05:12 AM
cvaria's Avatar
cvaria
i did the the s&s 110 power package last year with s&s 89cc heads, 58mm tb and intake, and 4.9 g/s injectors, i'm not in to custom head work. will be cool to see how your numbers look vs mine. i can get to see what i left on the table by refusing headwork.
Old Jan 13, 2018 | 06:25 AM
Arseclown's Avatar
Arseclown
Why are you against custom head work?
Your s&s heads obviously would have cost more than getting oem heads modded and you may not get the same gains?
Old Jan 13, 2018 | 06:59 AM
cvaria's Avatar
cvaria
why ask why? cost had nothing to do with it. see here:
https://www.hdforums.com/forum/gener...l#post16850905
Old Jan 13, 2018 | 07:51 AM
13glidestreet
Sounds like a good set up! You can’t go wrong with those heads s&s makes a top product for sure. I am sure our numbers would be right around the same. What were your final numbers?
Old Jan 13, 2018 | 07:53 AM
prodrag1320's Avatar
prodrag1320
S&S leave a lot to be desired out of the box.with proper porting,45-55 cfm can be had on both int & ex sides
Old Jan 13, 2018 | 08:32 AM
cvaria's Avatar
cvaria
122hp/120tq (rounded). fine for an off the shelf parts bin. i have not so great dealer dyno tune because there are no great tuner's near tallahassee and i don't feel like riding or carting the bike down to Doc in Orlando. good daily driver. TBH, i ride my sportster more, it's more fun.
not interested. i don't do head work or custom. if i wanted custom s&s heads, i'd go with the FM outlaws, https://www.fuelmotousa.com/p-28619-...d-porting.html
Old Jan 13, 2018 | 11:42 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
CVO 110" heads, at our Stage II Level, leave an S&S 2" valve Super Stock casting in the dust, no matter which way you shake it.
Not an opinion, and not a debatable comment.
Fact.
Scott
Old Jan 13, 2018 | 04:45 PM
cvaria's Avatar
cvaria
Fact.
Scott
good for your stage 2 heads. maybe to OP will go with them
