starter clunk
Old Feb 14, 2018 | 07:51 PM
bikermike777's Avatar
bikermike777
4th Gear
Default starter clunk
When starting my deluxe, the starter makes an initial loud knock noise. At least I believe it is the starter. It only does it once, then the bike starts up. Is this a clue that something is going wrong with the starter? Or is this a normal sound I should just get used to? 2011 Deluxe with just 2400 miles on it. Please help.
Old Feb 14, 2018 | 09:37 PM
2009blackpearle's Avatar
2009blackpearle
Default sounds like the compensator
there is a spring loaded compensator off the crankshaft up near your toes on left shifter area, chain connects it to your clutch basket, job is to absorb shock loads between crankshaft and drive line, they do wear out and stock design is a bit more fragile than the se version or a baker drive train one. I did change mine years ago then I started adding cams and 103 kit to my bike. if the spring is weak or clearances on the moving hub parts wear u get clunking
Old Feb 14, 2018 | 09:39 PM
bustert's Avatar
bustert
i assume you are new to the machine??
well starters do make noise. the first thing that must happen before the starter really starts to spin is the solenoid plunger retracts/extends to force the bendix gear into the starter ring gear on the clutch basket.
now if you had this machine awhile and the noise changed, it is worthy of a look-see to be safe, really just a gasket. that said, a battery that is wearing out is not as strong so the process takes a tad longer so maybe some more noise, load test it.
Old Feb 14, 2018 | 10:05 PM
bikermike777
4th Gear
Old Feb 17, 2018 | 07:14 PM
bikermike777
4th Gear
After digging into the battery information, I discovered the battery came from a CanAm Spyder Roadster (this is a sports dealership). The battery that they put on this Deluxe only has a CCA of 200 and Ah of 10. So, changing the battery out is first on my list. So we'll see.
Old Feb 18, 2018 | 11:39 AM
bustert's Avatar
bustert
how about boosting it with a lager battery and cables to see if it helps before cranking out 100+ bucks
Old Feb 18, 2018 | 03:13 PM
Nitro 54's Avatar
Nitro 54
The battery you have is marginal to even run your bike correctly. 10 amps ??????????
Old Feb 19, 2018 | 08:45 AM
bikermike777
4th Gear
Agree. I entered this battery info to my Amazon page and it came up with "This item does not fit your 2011 Deluxe" Called local HD dealership. New battery is 18.5ah and 315cca, big difference. Thanks.
REPO1
Aug 27, 2014 10:48 AM
MJ-13000
Sep 2, 2013 01:31 PM
c50plus
May 15, 2012 09:43 PM
RoadRich2010
Jan 4, 2012 09:31 PM
rotorhdh2
Jan 31, 2007 04:30 PM
