Starter noise only when hot. What could be?
Old May 15, 2012 | 08:53 PM
c50plus's Avatar
c50plus
Default Starter noise only when hot. What could be?
My 2008 Ultra always starts up very nicely when cold. But if I return from a ride
and get back to the bike in a few minutes, while the bike still hot, the starter
makes a horrible noise as if the whole bike is falling apart and then starts. what is going on?
Old May 15, 2012 | 09:02 PM
springer3's Avatar
springer3
First off what size motor?
And if its a grinding noise it might be starter drive or drive on back side of clutch and thats what make it sound like its coming part drive is weak and doesnt engage fully and grinds on teeth.
If it is making noise as if its week and you have big motor it could be compression when gets warm so what size motor and how long have you had bike?
If you have had bike threw heat of last year and it did not do it i would think that starter drive is getting weak!Thats if its a grinding noise if its another type noise try to explain noise..The starter is a pretty easy fix if you have the tools and table i would say it would cost you an hour labor plus starter!If its the teeth on back side of clutch basket its going to be around three hours and what they charge you for parts!!!
Old May 15, 2012 | 09:04 PM
springer3's Avatar
springer3
it also could be as simple as bat is weak to and not throwing enough juice to starter to engage all the way!you can put a meter on it and see how much it pulls it down when you hit the starter!! Just some ideas!!
Old May 15, 2012 | 09:08 PM
soft 02's Avatar
soft 02
Check connections first but my money is on the starter clutch.
https://www.hdforums.com/forum/searc...rchid=12930845
Old May 15, 2012 | 09:23 PM
X Iron Butt's Avatar
X Iron Butt
07 and up starters come right out in 30 minutes from your front door no outer primary removal. 45 minutes to clean up dissasemble and replace clutch. 30 minutes to put back in. $75 to $100 for ALL ***** clutch.
Old May 15, 2012 | 09:25 PM
09BlueRoadKing's Avatar
09BlueRoadKing
+1 on checking the batt. Mine was doing the same last summer, took it to dealer and had them check voltage, sure enough batt. was a little weak, no noise or starting issues after new one was put in.
Old May 15, 2012 | 09:31 PM
dwg1956's Avatar
dwg1956
Mine did the same thing until I replaced the compensator with the screamin eagle compensator now it starts great everytime hot or cold at 26,000 the original compensator was worn and pitted pretty bad
Old May 15, 2012 | 09:43 PM
springer3's Avatar
springer3
Talking
Dont forget to report back on what it is for sure!!!
REPO1
Aug 27, 2014 10:48 AM
SoFLJoe
May 22, 2014 06:59 PM
RoadRich2010
Jan 4, 2012 09:31 PM
customsoftail200
Jul 25, 2011 10:09 PM
Lrider
Mar 24, 2007 11:34 AM
