Cam for a TC88 Dyna
Though I love torque, I do not mind it if I have to rev my bike a bit. I was looking at an 030 gasket job and maybe throw in some 510's on my 2005 FXDCi. But I was wondering - is there something else I could throw in that would give me some nice lope, plenty of power all around(for a tc88), and be livable with? I don't really tour or bag it, and I rarely have another rider. What other cams should I look at where I won't have to mod the engine besides maybe some new springs and a gasket?
Obliged!
So words that I understand are: a 509 will give you more low to mid range TQ and HP, and maybe idle better(I assume that's what you are saying?)
What I was looking for is more mid and upper end HP and torque, and a more lopey idle.
I am adding a .030 gasket for more compression and might deck the heads depending on the costs.
m
I'll poke around and check on the 37's.
Another question regarding going to gear drives is, if runout isn't perfect, will it effect the reliability, or is it mostly gonna add that gear whine?
Thanks, guys!
Now, if the OP wants to open the discussion to shaving heads to increase compression to run cams with a later intake close, that's another subject. To run the 510 or the 37, even with a .030" head gasket and a .040" cut on the heads, the motor will be soft on the bottom, come on in the mid and upper range but the stock heads are going to hold TQ/HP back as the motor revs.
We still don't know if the motor is carbureted or EFI or the model year; not that it makes a big difference but if we are talking 05 up, the beehive springs can handle higher lift cams, which, again, without head work higher lift won't help much. If we are talking '06, better heads.
For the 510 and 37 cams to work well, static CR should be 9.6; 9.8 would be better but would require a severe cut on the heads and valve to valve and valve to piston becomes an issue; those two work much better in 95"/98" motors. I have cut heads to 76cc and run SE204 cams which have a high TDC lift, higher than the 510s or 37s with no issues. Intake manifold fitment can also become an issue with a .060" cut on the heads. A .040" cut on the heads certainly helps and if the OP goes that route, the SE204 would be a better choice than either the 510 or the 37 and will provide the OP with the "lope" he is looking for, be not quite as soft on the bottom, very strong in the midrange into the upper range where the heads come into play and start holding back the HP as previously stated.
The OP would have to pull the heads and measure the chambers to be able to actually predict the results; I have seen TC88 heads measure 89-90cc.
JMHO but I don't think the OP really knows what he wants or how to get it.
I stand by my original suggestion; run the S&S 509s, replace the inner/outer cam bearings and replace the tensioners with the CYCO tensioners. Fuel management of some sort should be part of the plan as well if the bike is EFI; if carbed, a rejet will be required.
Everybody wants to over cam these motors and when the do, the little TC88 can't pull itself out of its own smoke and they wonder why.
Gear drives require crank runout to be .003" or less. With the chain driven hydraulic tensioner, roller chain options available, gear drive is not as popular an option as it was when it was the only option to eliminate the early OEM cheesy tensioners.
I dyno'd an 02 RK @89 hp and 95 tq with true 2-2, stock heads milled 40 and stock everything else and that bike ran killer from 2800 up. (with the 510 cams)
The OP should think, in my opinion of changing his pipes from the short shots which in my experience have been great sounding, but a power robbing system, much better performance from a better pipe choice. the 030 head gasket is not really going to do squat for a comp increase, the stock gasket is 045, so going to the 030 is not going to give enough to make it any better, to me taking 040 of the heads and cc matching would be a better approach as I too have seem similar volumes as large as 90cc.
i also do agree that the SE204 would not be a bad choice either, the bike will just need a good tune, IIRC the 05 dyna's were all injected, so some sort of fuel management is gonna be a must.
in closing, to the OP, if you are going to remove the heads, just do it right, go to a big bore, 95 or 98 your choice, 510, 204, or tw 37 cam, better exhaust, try to get 9.75 to 10-1 comp and tune it up. should make you grin and stay healthy for a good long time, asssuming that you dont ride like a bone head!!
m
