Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
One thing to note here is I did not remove the throttle body, only the air cleaner and backing plate. Could an air leak at this level cause the idle issue?
Yes. Did you install the gasket between backing plate and intake?
Yes we do have the tools necessary to remove and install the inner cam bearing on the M-8. Tool 320640 is needed for removal list price is $95.50. Tool 820650 is for installation list price is $98.95. I will gladly take an order over the phone (ph hours are from 8 to 4 pst) or if you supply your shipping/billing information we can send an invoice through PayPal.
Yes sir going to pull everything apart tonight and check it out.
Well found another air leak at the manifold where it goes into the head, starting another tear down soon. Hmm wonder if I can put bigger injectors while I am in there?
you can but,but your stock injectors will give you all the fuel you need or want with what you have
