Your 3 best performnce tricks
Old Nov 26, 2018 | 11:59 AM
Kingglide549's Avatar
Kingglide549
Default Your 3 best performnce tricks
Performance tricks that work!
Rules 1--three per post, if you wish to list more.
do so next in line .
We can all steal each other's ideas.
I would like to know what others do here
2, You have had to actually do this not read about it.
My best ideas have come from others and will gladly give them credit
For starters- start-
I have read a lot of Joe Mondello. I think that has been one of my biggest tricks as applied performance and IC science.
3- things that work and cost nothing but time is-
1, -Check your valve seats! We could get into numbers-, but for simple,-
make sure there are no 'proud edges" sticking out. I can guarantee there is!
Smooth them off flush with the port.
2, -Make a ponty bow on the guide bosses and depending on your application make the guide no longer then they have to be.
3, -Install OS valves - on a EVO the same seats are used. Again depending on how long you want it all to last (trade for power)
set the seats narrow and way high.
Your turn.
Old Nov 26, 2018 | 02:13 PM
Max Headflow's Avatar
Max Headflow
Increase displacement,
Increase flow.
tune it well,
Old Nov 26, 2018 | 02:25 PM
Super Glidester's Avatar
Super Glidester
1. Burnout
2. wheelie
3. Stoppie
Old Nov 26, 2018 | 02:41 PM
Kingglide549
You guys are so deep...................
Old Nov 26, 2018 | 04:10 PM
tootal's Avatar
tootal
1. Displacement
2. Porting for said displacement
3. Proper cam to place the power where you want it.
Old Nov 26, 2018 | 04:16 PM
TriGeezer's Avatar
TriGeezer
Old Nov 26, 2018 | 04:21 PM
Notgrownup's Avatar
Notgrownup
Power commander
SE Air Filter
2 in 1 E series exhaust
Kapow, drop he mic.
Kingglide549
No you guys are truly missing the point
As in-
Porting where?
raised ports?
sized where?
what kind of cam .
Anyone can add displacement-I was hoping we could exchange some real ideas what was actually done,
What actually worked in the details, not the globs of added parts so much to get more power.
I did my best to show an example above, - detailed example.
Your tricks ?
Old Nov 26, 2018 | 05:38 PM
blackjeep's Avatar
blackjeep
Not a trick but works.
Better gearing.
30 tooth output pulley on my 2010 touring.
Amazing difference.
Old Nov 26, 2018 | 05:54 PM
QC's Avatar
QC
1) $
2) $$$
3)$$$$$
