Cam choice thoughts
Old Feb 5, 2019 | 09:19 PM
98hotrodfatboy's Avatar
98hotrodfatboy
With a stock setup and having hot start issues I wouldn't think it was compression doing it.. Something else going on...
Old Feb 6, 2019 | 08:49 AM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by Weeboy1
understood, but was having a slight hot start issue
Check and examine your compensator.
Old Feb 6, 2019 | 09:20 AM
Weeboy1's Avatar
Weeboy1
im not getting the typical clunk or kick back.
just more like the starter tries to engage then grinds/spins. And it does it infrequently.
replacing the starter clutch would be cheaper and easier and if it doesn’t correct it then I was going to look into comp.
thats my thought anyway
Old Feb 6, 2019 | 09:28 AM
djl's Avatar
djl
As has been said, both the 48 and the 570-2 are great cams. However, based on the OPs comments WRT his goal of low to mid range performance and not seeing 4500 very often, still thinking S&S 551 and I would definitely address the higher CCP with EZ starts.
Mackdyna
Engine Mechanical Topics
Mar 15, 2018 07:16 PM
banjoplayer2
Mar 27, 2014 12:12 AM
PHA-Q
Exhaust System Topics
Apr 29, 2011 10:28 PM
Rick Lees
Aug 20, 2010 02:49 PM
uniondog
Mar 8, 2007 12:34 AM
