Left side compensator assembly HELP!
Old Apr 14, 2019 | 01:44 PM
2k2ss's Avatar
2k2ss
Default Left side compensator assembly HELP!
I have a 2017 dyna s I had the 110 engine converted to a 124 using stock cases and an S&S crank. The lower end was built by a reputable builder. When I put on the washer against the crank bearing then the spacer then alt rotor then the splined shaft extension then the compensator sprocket. The shaft extension is even with the end of the crank shaft so there is no splines left for the sprocket retainer to engage! WTF I’m crapping myself here!!
Old Apr 14, 2019 | 04:21 PM
joe40x's Avatar
joe40x
The washer should be inside the case behind the seal.
Then the spacer goes thru the seal and against the washer.
Old Apr 14, 2019 | 04:52 PM
joe40x's Avatar
joe40x
Old Apr 14, 2019 | 06:20 PM
2k2ss's Avatar
2k2ss
Thats the way I have it. I think the spacer is to long! The rotor doesn’t even cover all of the stator only about half.
Old Apr 14, 2019 | 06:22 PM
2k2ss's Avatar
2k2ss
I even pulled the seal out to make sure the washer was against the bearing.
Old Apr 14, 2019 | 07:37 PM
Max Headflow's Avatar
Max Headflow
If the guy installed timken main bearings, the spacer needs to change.. Call him.
Old Apr 15, 2019 | 03:18 AM
2k2ss's Avatar
2k2ss
Yes he did do timken conversion. Just didn’t want to call on Sunday
Old Apr 15, 2019 | 05:06 AM
joe40x's Avatar
joe40x
Spacer from '99-02 IIRC. I could be wrong
Old Apr 15, 2019 | 06:03 AM
prodrag1320's Avatar
prodrag1320
use HD # 11887 or drag specialties # 1106-0074,these are required when converting to a Timken set up.sent a email on this with head tq requirments & start up instructions,did you not get it?
Old Apr 15, 2019 | 06:38 AM
2k2ss's Avatar
2k2ss
Just seen email thanks!
richard567
EVO
Jun 5, 2017 04:51 PM
Pinetop
EVO
Apr 28, 2014 08:10 AM
txwrench
May 26, 2013 01:40 PM
49pan
Panhead
Feb 19, 2010 06:33 AM
gunnert
Exhaust System Topics
Sep 18, 2008 09:33 AM
