Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
1 or 2,3 is basicly a trick question.#1 is fine as long as the t body isn't too big and the port too small and the port is matched to the runner (will still work,the port will just be a choke point) #2is pretty much what your looking for as long as everything is set to the rest of the build
