Engine build help.
Old Oct 1, 2019 | 10:46 AM
djl's Avatar
djl
Originally Posted by SGLife
I did look at the S&S crate motor's along with SE 120's but they are not going to be tailored to my needs and not built as well. I think for the same cost I can build a balanced 124" engine for the same cost as a crate and it will make better power. Too say I'm not going to run the new combo hard would probably not be a true statement this Is why I'm doing the work to feel some performance plus I do allot of wrenching myself which helps with cost. I don't think the stock untouched crank would last very long at 130hp running it hard and why have that much power and not use it. I was planning to chatting with Darkhorse for the crank work I think they have their line of nice cranks so I'm not dead set on S&S at least in stock form.
Not throwing rocks at your plan but if the plan is to build the 124" motor on other cases as you indicated in your OP, you are going to spend more than what an S&S crate motor would cost; you should trust me on this. You either buy cases or a trashed motor as the base for the build and once you spend the $2K to get the lower unit worked, i.e., cases or motor, Timken conversion, case boring, crank, etc. you will have to buy everything else, nothing from your 103 will be used except the ECM and fuel management if you have it. I am not pushing S&S but they offer high and low compression motors in various configurations and I am certain you could configure one that suited your riding style and it would come with a warranty. You blow up your DIY 124" and its back to the drawing board and piggy bank. It matters not to me which way you go but to avoid a money pit, take yout time, listen to those of us that have "been there, done that" and do the home work in a thoughtful way. JMHO.
Old Oct 1, 2019 | 11:36 AM
ntraindavefl's Avatar
ntraindavefl
This comment is unsubstantiated. Let’s find one post of a twisted late model crank putting out up to 130. Riding hard won’t do it, using all the power won’t do it, above and beyond abuse might get it to move but maybe not. A stock motor could bung up a crank if lugged then WOT for example with regularity. I’ve done a dozen builds ranging from all out 107s to all out 124s and 131ci. The 107s were beaten on every ride but with shock loading avoided, full rpm use but keeping the instigation of horseplay above 3200 rpms. Don’t let the myth of cranks imploding over 120/120 cloud your decisions. Build the 124 by all means, just be prepared if using even your existing cases the total cost will run 8-10k with all the peripheral components you’ll need. As djl has mentioned you’ll use nothing on the bike now unless you have the right pipe. Clutch, intake, injectors, tbody, tune, larger oil cooler, roller rockers, camchest.....and possibly more if done right.
Old Oct 1, 2019 | 01:39 PM
SGLife's Avatar
SGLife
You are correct I only know what I read on the stock cranks but lets say I do a 107 or 110 kit on that and it grenades then I'm back in the same boat. I'm not new to building things and know power comes with a price tag. I do know if I was to build from scratch it would be very select parts on a well balanced bulletproof lower end yes it may cost 8K but I think it will be better than you could buy crate motor wise plus tailored to me.
Don't take me as cocky I did ask for help here and it will all soak in before I make up my mind and greatly appreciate the wisdom that comes my way.
Let me ask are there any weak spots in the 124 S&S crate engines? I know the SE 120r has crappy lifters and heavy valve springs but if I could get into one of those without needing to swap too much out I will consider that route.
Old Oct 1, 2019 | 02:30 PM
djl's Avatar
djl
JMHO but I would not go the SE120r route without taking the top end apart to verify cylinder to piston fitment, ditching the heavy valve springs, probably replacing the cam set and definitely replacing lifters and push rods. I know of several S&S 124 installs that have made the owners very happy but I do know of one that had issues; the motor never performed as it should. S&S replaced the motor at no cost to the owner after several attempts to solve the problem failed.
Old Oct 1, 2019 | 05:47 PM
SGLife's Avatar
SGLife
Does anyone know the exact components in a S&S T124 crate engine? I cant find out this info and S&S refereed me to the owners manual which don't tell you much!
Old Oct 1, 2019 | 05:58 PM
SGLife's Avatar
SGLife
Is this the kit they would use to build the crate 124 ?
https://www.sscycle.com/products/124...wrinkle-black/
Old Oct 2, 2019 | 10:01 AM
Sambo62's Avatar
Sambo62
I had a 110" build done on my 103". New cylinders, pistons, cams, TB, injectors, clutch, etc... Total out-of-pocket cost with tune approx $6k and I did none of the work due to personal time constraints. 126 ft-lb / 122 Hp. Didn't touch the bottom end. Ran it hard all summer, no issues so far. Perfectly happy...
Old Oct 2, 2019 | 11:10 AM
djl's Avatar
djl
1. I don't know if I understand the question so, two answers. I don't know if that is the kit S&S uses to build a crate 124" motor but did not see a cam plate/pump included and I am pretty sure S&S would use their cam plate/pump to assemble a crate motor.
2. You could go that route but would still have to send lower unit to Darkhorse for case boring and Timken conversion which will cost mas o menos $800 and another $165 if you want the crank plugged or $30 if you want it welded. As I said in #1, I did not see a cam plate/pump in the linked kit and would definitely not run the OEM cam plate in a 124" motor and might replace the oil pump; more money. Why not throw another $500 at the project and get an assembled motor?
Old Oct 2, 2019 | 04:53 PM
SGLife's Avatar
SGLife
Sorry if I was vague but I was just trying to figure out what exact parts are used in the T124 crate engine and was just assuming that kit was the bulk of it. I did not plan on adding it to my engine.
The S&S crate 124 comes with their TC3 plate and pump just don't know if it has a Timken bearing setup.
rhuff
Engine Mechanical Topics
32
Sep 11, 2015 10:32 AM
blink1968
Nov 6, 2011 11:14 AM
jrfernandez7
Aug 2, 2009 10:54 AM
csbreeze
Jan 31, 2008 01:54 PM
dlstanf2
Exhaust System Topics
Feb 11, 2007 10:50 PM
