New Build, power spitball estimates......
Old Apr 6, 2020 | 09:50 PM
  #31
ntraindavefl's Avatar
ntraindavefl
The first fire up, always a relief. Nice
Old Apr 9, 2020 | 05:19 PM
  #32
marcodarq's Avatar
marcodarq
ok, preliminary fuel tuning has me in the ball park at this point. the base map i got to start with was pig rich, EVERYWHERE!!!!. i've got 20 plates with a closed end cap on the old e-pipe, and making 107 hp and 115 tq on a 5th gear run. the graphs aren't that pretty and i've not done any spark tuning yet. i hope that there is more in there, but 'ill report again after i get the spark timing worked out and the final tune done.
m
Old Apr 10, 2020 | 06:26 AM
  #33
prodrag1320's Avatar
prodrag1320
m
on a average,pretty much same kits are in the 115-119/120-124 area.i would assume this one will end up there too
Old Apr 10, 2020 | 12:07 PM
  #34
djl's Avatar
djl
ok, preliminary fuel tuning has me in the ball park at this point. the base map i got to start with was pig rich, EVERYWHERE!!!!. i've got 20 plates with a closed end cap on the old e-pipe, and making 107 hp and 115 tq on a 5th gear run. the graphs aren't that pretty and i've not done any spark tuning yet. i hope that there is more in there, but 'ill report again after i get the spark timing worked out and the final tune done.m
I will be disappointed if you don't find more. I would be looking at the pipe for more; might need more T/B. Love to see a sheet.
Old Apr 10, 2020 | 01:44 PM
  #35
marcodarq's Avatar
marcodarq
i went from 14 plates up to 28 plates on the pipe, couldn't seem to find anything there, 50mm tb was all i could afford. as i said before, the base tune was super rich all over, i'm also not real happy about what the spark timing tables look like, but it was good enough to get it to start and run, so when i get a bit more time, i'll get back to working the spark and hope that i can get more. i will post up graphs once i get things closer to correct or if i get stumped on something, or once i'm done and happy..
m
Old Apr 20, 2020 | 05:35 PM
  #36
marcodarq's Avatar
marcodarq
ok, i'm up to 112 hp and 126 tq. still trying to work through some gremlins and knock control issues, but closer to the end. when i'm done i'll post up the finished graphs. very nice and broad torque curve.
m
Old Apr 21, 2020 | 06:43 AM
  #37
prodrag1320
m
when done.email a copy of the sheet to veetwinracing@hotmail.com i like to keep them on file
Old Apr 21, 2020 | 04:43 PM
  #38
marcodarq's Avatar
marcodarq
OK, i will, thanks for the fine work!!
m
marcodarq
Exhaust System Topics
Nov 6, 2019 09:08 PM
ReapersWG
Sep 6, 2012 07:05 PM
62pan
Jan 30, 2010 06:54 PM
EasyG
Sep 26, 2009 09:47 PM
tom73
Jul 28, 2007 08:36 AM
