Winter build
Old Nov 8, 2019 | 07:10 AM
ntraindavefl's Avatar
ntraindavefl
Originally Posted by wfolarry
They don't & since you already have the 585 cam this would be a great build for you.
At 10.5/6 static....great touring reasonable ccp
Old Nov 8, 2019 | 03:01 PM
eriksweden's Avatar
eriksweden
Originally Posted by Screamin beagle
Fuel pump will be fine...might consider going to 5.3 injectors though. Better check you crank runout too...you going to put a lot more power to a motor with 57k on an already suspect bottom end. I have an 08 cvo road king and stayed at 110 but did heads and s and s 570 cams over last winter. Had about 43k on the bike at the time and .003 runout with great oil analysis results. About 7k into this riding season and I hit the rev limiter once by accident passing a few cars and the crank shifted and I found bad rod bearings on tear down. Cured with a darkhorse man o war crank. Don't let my story discourage you...build your motor and if the crank takes a crap on you then fix it. With bad bearings I was on borrowed time anyway, but now when I need to I can build a big power motor and not have to worry about my bottom end again. Good luck with the build
About bigger injectors , is there any good way toraise fuel pressure instead ?
Old Nov 9, 2019 | 06:19 AM
prodrag1320's Avatar
prodrag1320
Originally Posted by fathead1137
I have not as thought the 124 would create too much heat for touring
Old Nov 9, 2019 | 06:20 AM
prodrag1320
well,whoever told you that is wrong,you do realize the 117" uses the same bore cylinders as a 124,right? (4.125 bore.117 uses a 4.375 stroke,124 uses a 4.625)
Old Nov 9, 2019 | 08:26 AM
Screamin beagle's Avatar
Screamin beagle
[QUOwTE=eriksweden;18662303]About bigger injectors , is there any good way toraise fuel pressure instead ?[/QUOTE]
im no expert and maybe kirby or someone can explain it better. Even if you had 100 psi from the fuel pump the injector still dictates how much fuel can be put into the motor over a given period of time...controled by the tune. If I'm wrong, feel free to correct me. As far as going 124, I took it thst the op was going with the 117 drop on from HD and hadn't planned on splitting the cases...yet lol.
Old Nov 17, 2019 | 02:11 AM
bklynbob's Avatar
bklynbob
CR 575 @ 10.25-1 makes a great touring motor. Good luck on the build.
Old Nov 17, 2019 | 05:57 AM
fathead1137's Avatar
fathead1137
Bike should be ready in a week getting a s&s oil pump and cam plate and Barney basket and clutches with new compensator
Old Nov 17, 2019 | 08:42 AM
jbarr1's Avatar
jbarr1
A Barney basket? Must be purple!
I know— it’s a Barnett— it just struck me as funny.
Old Nov 17, 2019 | 07:39 PM
fathead1137
Hey it was a late night
Old Nov 17, 2019 | 10:14 PM
fathead1137
Now I’m installing s&s cam plate and oil pump, S&S tensioners and install the lower cam sprocket and inner cam bearings. Anything else I should look at while in cam chest? Is 594 to much of a cam for this build or is the 585 the way to go?
Just Cruzin'
Milwaukee Eight (M8)
Jul 12, 2019 11:11 PM
jdsimp
EVO
Feb 25, 2015 09:35 PM
johnnyjellybean
Feb 2, 2014 12:12 PM
jcoopercam
Engine Mechanical Topics
Jul 3, 2009 03:20 PM
FLHR
Exhaust System Topics
Aug 11, 2005 12:22 PM
