Remove oil relief valve
Old Dec 2, 2019 | 08:59 AM
djl's Avatar
djl
As Ed has pointed out, the crank seal is the most likely culprit, so replacing it is the obvious move. Seems that seals don't know how many miles have been rolled up before they fail; they just fail. Since the cam chest is open, no harm in checking the relief valve piston. Pull it out and polish it with a Scotch Brite pad; it should move freely in the in the bore. If it falls out when you remove the spring, you will know it is OK but as Ed also pointed out, high oil pressure is not pushing motor oil into the primary. New breathers are cheap, just buy new rather than rebuild?
Old Dec 2, 2019 | 11:16 AM
Peter Carreiro's Avatar
Peter Carreiro
djl, I agree w you. I have seem many seals fail w/o any apparent reason. I know that replacing it at this point is the logical practice. I don't have the cam chest open yet. I was just planning for the future if in fact the problem of transfer still exists after replacing the seal and spacer, and after new parts in the breather system. I will be placing new umbrella valves, gaskets and 'gauze' in the system. I will also check for true-ness of the metal components, considering the fact that the breather system is a likely culprit even though the system 'seems' to be functioning. Thanks
Old Dec 2, 2019 | 03:21 PM
djl's Avatar
djl
OK, if the cam chest is not open, do as Ed suggested and attach a known good mechanical oil pressure gauge; you many not need to open the cam chest. All I was saying about the breathers was for about $12 more, you can replace with new rather than rebuild with the rebuild kit; your call of course.
Old Dec 2, 2019 | 03:24 PM
Peter Carreiro
djl, thanks for the input. I appreciate all reply's.
Pops98
Feb 1, 2015 05:05 PM
f4dennis
Engine Mechanical Topics
25
May 27, 2014 10:10 AM
mrfuji
Aug 15, 2012 06:48 PM
Mogar
Mar 18, 2011 09:33 PM
toolbox
Jul 20, 2007 10:14 AM
