Big Bore Kit
Old Nov 25, 2019 | 11:38 PM
  #31
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by 1 2 many
So your saying no one can build a 107 that can produce more hp/tq than your lazy 124?? All have you eat crow instead of those protein shakes . My build came with the 996 cams not 999. Look it up on FM site it's called a 107 outlaw kit night night
I believe what ntraindavefl is saying is that if you are going to post performance numbers associated with your build, you should also post the associated dyno sheet, and I agree. Otherwise, just post your build information and leave it to the readers to interpret/assume what it may be.
Plus, if you are going to post build information, at least have the courtesy to post accurate build/part number information,
What's a 996 cam? Is it a WM8-9960 or maybe a TW-999-6 or maybe a TW-999-6A?
Old Nov 26, 2019 | 12:52 AM
  #32
1 2 many's Avatar
1 2 many
here we go cp pistons 13cc dome (CCP @210) comp @10.8 S&S heads 2"in 1.610 ex 89cc 58mm Se with 5.3 grams woods tw996 cams S&S push rods S&S oil pump. Stock crank 32t twin power solid comp with aim variable pressure plate D&D fc tuned with powervision target tune. Tuned by hiro koiso. Oh yeah on pump gas 91 octane and 20k on the build so far.
Old Nov 26, 2019 | 05:39 AM
  #33
ntraindavefl's Avatar
ntraindavefl
uhh what??....all over 200ccp stout motors that some pick up wheel at 1/4 throttle wout clutch dump. Look I am fortunate to have the dollars and time to do what I’ve done so wout me rubbing it in let’s stick to the 107 topic at hand. The only lazy thing going on here is you....you keep saying your 996 cams.....news flash there is NO SUCH CAMS!! They’re wood 999-6. So please if you want to fudge your dyno claims etc...at least know the names of your PARTS. That shows us the level you’re at right there.
Old Nov 26, 2019 | 10:27 AM
  #34
1 2 many's Avatar
1 2 many
Smile
I dont have to lie about what my small 107 makes. Whether you want to believe it or not. I ain't the only one for example star racing also makes a kit with more hp/tq than mine and hillside tman FM zippers kendall johnson but hey I must be making it up and spreding misinformation. These kits evolve. who knows tommo there might a kit that makes more hp/tq and still have it reliable
missedem
Sep 3, 2020 08:06 AM
Insulatorman17
Oct 21, 2015 09:24 PM
lwfuller
Aug 3, 2011 11:41 AM
bigmikaele
Jan 10, 2009 01:28 PM
Raxus
Jan 16, 2008 08:18 AM
