Big Bore Kit
Old Nov 24, 2019 | 06:53 AM
sixgun95's Avatar
sixgun95
Default Big Bore Kit
Looking to do a big bore kit for a 2015 Ultra Limited, 103". Want to go as big as possible, yet maintain reliability. Not set on a particular manufacturer, likely FM or one of the other sponsors. Money is not the driving factor, doing it right the first time is. Was thinking a 117 or 124, or would a 107 be the best choice? Thoughts?
Old Nov 24, 2019 | 01:41 PM
rhuff's Avatar
rhuff
No one can determine what the "best choice" is for you without A) A budget and B) expectations power-wise, despite wanting reliability. A 107, 117, or 124 can all be made uber reliable. You need to answer A & B so the forum can help you.
Old Nov 24, 2019 | 03:56 PM
sixgun95's Avatar
sixgun95
Fair question, budget is no more than 5k and I already have a D&D Fatcat. For power, I would like to attain 125/125, as a minimum and keep the rideability and reliability.
Old Nov 24, 2019 | 04:07 PM
grbrown's Avatar
grbrown
You mention FM, who are an HDF sponsor, as also are Hillside Cycle and possibly others. Check out the Vendor Directory above and phone one or more of the tuning specialists, to talk through your options. That will help you answer the points made by rhuff above. Don't be surprised if you get enthusiastic over something more than you initially planned!
Old Nov 24, 2019 | 07:39 PM
HARDWAY90's Avatar
HARDWAY90
2nd Gear
Well the highest displacement you can go from a 103, is to a 110 kit without removing the whole engine to bore out the cases. Just a start on answering your question.
Old Nov 24, 2019 | 10:58 PM
rhuff's Avatar
rhuff
Well, you have the exhaust at least. Your best bet for 125/125 within your budget is either a 110 with head work or a 107 with headwork. Personally, 125/125 from a 107 is easily do-able, but you're going to be running on the edge of reliability. Not that it's not "reliable" perse, but you're at 1.16 HP per CI with a 107.
Talk to a forum sponsor or find a reputable local builder. Where you live?
Edit.... I see AZ.
Old Nov 24, 2019 | 11:44 PM
sixgun95's Avatar
sixgun95
Edit.... I see AZ.
Looks like a 106/107 or 110. Any recommendations on which to go with?
Old Nov 24, 2019 | 11:52 PM
shaggieshapiro's Avatar
shaggieshapiro
You say that you have a D&D exhaust? The owner of D&D has developed a set of cams that will give you an unbelievable amount of torque that you won't need a bore kit. Try calling him
Old Nov 24, 2019 | 11:54 PM
rhuff's Avatar
rhuff
For 110, the S&S kits have been very reliable from the reports. I'd piece-meal it though because you're going to need headwork to hit 125/125. You need to talk to a builder IMO. A 107/110 without headwork isn't going to happen.
Old Nov 25, 2019 | 01:43 AM
Tat2u's Avatar
Tat2u
A lazy 124 cube would be the go, would need case boring of course.
how much of the disassembly/reassembly can you do yourself? If a shop has to do the lot things will add up quick.
And you always go over budget ha ha, your 5k will more than likely become 8k as it's not just about bigger slugs and jugs.... factor in cams, headwork, injectors, maybe new manifold, new lifters, clutch upgrade, tuning (preferably a reputable dyno tuner) the list goes on..
