120R Engine modifications
Old Nov 29, 2019 | 09:33 PM
JBeedy's Avatar
JBeedy
Stage I
Default 120R Engine modifications
Hey guys, new to the group and was looking for some input from people with more knowledge than me on twin cams and what I can do with the engine. A little background on the bike:
It's a 2014 Street glide with about 11k miles on it. The bike was put together and sold with a 120R off the show room floor as their flashy bike. I picked it up last summer with around 6k on it. My questions/ what I'm looking for advice on is what are my best options to get a little more out of the engine without making it a time bomb. Currently it's making about 125/125. Overall, its a great bike and a lot of fun to ride.
When the motor was installed, it had roller rockers, adjustable push rods, 58mm TB, High Flow SE AC, D&D 2-1 exhaust, and a 1.5Q SE pan installed.
I have a set of TW408-6 cams that's were in my father's bike for a short amount of time. I'd love to reuse these and build off these cams (assuming they run well with my goals, the shop told him they had to go as part of his detuning to run pump gas). What else should I be looking at?
Are the 120R heads sufficient flow wise for these? Or should I be looking at machining for a higher compression/ porting?
Is the 58mm TB larger enough or should I go larger? I believe it has 5.3 injectors so I'm assuming those will have to increase? I do a lot of low speed riding, from what I've read the larger TB's make the drivability a little more of a challenge.
Im assuming I should have the crank worked/ welded? What are the limits on the stock cranks?
Reading, it seems a higher volume oil pump is recommended? Is this more for built engines, or is the stocker insuficient?
What should I be looking at for valves/ springs? Are the stockers okay?
Im basically looking for more power under 4500 rpm. I do a lot of both city and highway riding.
​​​​​​​ I hope I didn't make this too long and thanks advance! I look forward to everyone's advice/ experience.
Old Nov 30, 2019 | 06:35 AM
prodrag1320's Avatar
prodrag1320
replacing the OEM junk crank with a S&S unit & adding a timken conversion will give the motor reliability,add a set of S&S lifters,some cams that fit your riding style,match compression & headwork to them and 140+/140+ is well within reach
Old Nov 30, 2019 | 08:17 AM
rigidthumper's Avatar
rigidthumper
Here's one I did winter of 2013. 120R @ 11.3CR, T-Man 662-1 cams, D&D Boarzilla, Hillside ported CVO heads, Darkhorse crank, SE58TB 5.3 inj, SEHB.
Old Dec 3, 2019 | 06:00 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
That was a good combo, Robin!!
Scott
Old Dec 4, 2019 | 08:45 AM
Breakout110's Avatar
Breakout110
Would be great to see what the 58mm HPI Trottle Body would do for the 120...
What breather was on the 120 for the Dyno run?
Old Dec 4, 2019 | 07:19 PM
flanigans45's Avatar
flanigans45
My motor has TW-9F-6 cams. Rush Wrath exhaust . HD Race Tuner.
scuba_steve
Engine Mechanical Topics
27
May 20, 2021 06:37 PM
Fat11Lo
41
Sep 13, 2017 12:08 PM
Kustrud
Sep 29, 2014 11:54 AM
ultraclassic53
Nov 1, 2012 02:42 PM
HDCrossbones09
Jul 4, 2012 09:40 PM
