Thread lock
Old Dec 22, 2019 | 10:02 AM
gsbuick65's Avatar
gsbuick65
Default Thread lock
Replacing my compression releases and book says use 246 thread lock on reassembly, nobody in Memphis has it, think I can use high strength in its place?
Old Dec 22, 2019 | 10:31 AM
ROCKOUT Rocker Products
Sponsor
246 is for high temp (450f) usage... I would stick with what's recommended.
Amazon can have it to you Tuesday
CLICK HERE CLICK HERE
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Dec 22, 2019 | 09:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted
Old Dec 24, 2019 | 07:56 AM
memphisharley's Avatar
memphisharley
I just installed a time cert in my HD F150 and have some high temp locker. I'm up the street from you and would let you use a few drops. let me know.
Old Dec 24, 2019 | 05:12 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Did the plug dent the hood when it left the cylinder head?
Old Dec 25, 2019 | 07:53 AM
memphisharley
yes it did...not too bad but you can definitely see where it hit.
Old Dec 25, 2019 | 08:39 PM
Max Headflow's Avatar
Max Headflow
I use antiseize.
Old Dec 25, 2019 | 08:45 PM
TwiZted Biker's Avatar
TwiZted Biker
Do NOT use that on something that needs to be removable, that grade is designed to be permanent. Regular blue loctite is fine .
Old Dec 26, 2019 | 06:00 AM
RANGER73's Avatar
RANGER73
Does he have to give it back after he uses it?
Old Dec 26, 2019 | 06:29 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
You could also look for 2422 which has an even higher operating temperature
https://henkeladhesivesna.com/henkel...inal_Links.pdf
Palm Labs adhesive 11-HT is equivalent
http://www.palmlabsadhesives.com/pro...threadlockers/
TimoB_FL
Electrical/Lighting/Alarm
Dec 13, 2019 07:56 AM
springers4ever
Engine Mechanical Topics
18
Jan 17, 2018 05:35 PM
BigWaterJim
Sep 24, 2017 05:45 PM
almostakeeper
2014-2024 Touring Models
11
Sep 17, 2017 06:56 PM
ottomatics
Milwaukee Eight (M8)
Aug 21, 2017 08:55 AM
